Leaking near Valve Cover Bolts
Old Mar 9, 2016 | 01:59 PM
thedugger1's Avatar
Default Leaking near Valve Cover Bolts
I had a hell of a time doing the valve covers a few weeks ago. There were no copper washers in this section and instead a metal bridge piece. It was pretty mangled when I took it off, so I removed it and went with copper washers.
Of course, the only area it's leaking is here. They are new copper washers gooped up with a decent amount of Hylomar and torqued to specs. If you look closely, you can see some scratches in the surface that I believe is allowing the oil out.
What would you guys/gals do on this??
Old Mar 9, 2016 | 02:11 PM
Japawels's Avatar
I experienced similar problem. Taking the cover of and removing the scratches with fine sand paper solved it all.
Old Mar 11, 2016 | 08:05 PM
thedugger1's Avatar
Turns out that center "scratch" is actually a hairline crack! I found the original bridge piece and cleaned both surfaces well. Obviously worked well whoever did the repair originally (looked old). Question though, what do you think would work well (RTV, Jweld, etc)? Or more specifically, what would you think the grey mating material shown in the picture above was?
Old Mar 11, 2016 | 08:26 PM
Doug's Avatar
I've fixed a couple sets of cam covers with JB Weld. It does the trick
Old Mar 20, 2016 | 09:56 AM
thedugger1's Avatar
Happy to have fixed it...at least so far. A dab of Permatex Liquid metal filler and hylomar blue.
Old Mar 20, 2016 | 10:02 AM
thedugger1's Avatar
https://cimg4.ibsrv.net/gimg/www.jag...389a6a10fc.jpg
Cooper56
Mar 14, 2016 01:43 AM
TexMurphy
Mar 13, 2016 09:07 PM
rsq911
Mar 13, 2016 05:30 AM
Shelorr
Mar 9, 2016 08:46 PM
trav2010xf
Mar 9, 2016 01:02 PM
