Lock & Rock
Old May 24, 2015 | 11:17 PM
adenshillito's Avatar
Default Lock & Rock
again, novice at this so excuse my obvious mistakes&or-ignorance.
ok, XJ6, all wheel rolls fine but as soon as I bolt the flange thing at the back of the transmission unit to the propeller shaft thing (i.e. the circular plate with 4 bolt holes) the car (hand brake off) locks solid and will rock but no roll.
engine/auto 1985 installed in Series 2 body.
any ideas?
i'm puzzled
Old May 25, 2015 | 12:20 AM
Doug's Avatar
Is the transmission in "Park"?
Old May 25, 2015 | 02:34 AM
just went and re-checked all the gear positions to be sure, the situation is the same in each position. hand break is definitely off. car rocks but no roll. wonder if I have reattached the gear stick linkage to the transmission incorrectly.>?
Old May 25, 2015 | 07:37 AM
Doug's Avatar
You may have attached the gearshift linkage incorrectly....but that shouldn't the cause of your not rolling problem.
The car should roll with the transmission in any position except "Park". Only "Park" will lock the transmission, assuming all is well inside the transmission, of course....which I beginning to wonder about
Old May 25, 2015 | 09:28 AM
JagCad's Avatar
Yeah, stuck in park, sounds like the culprit.
1. Climb under. disconnect the shift cable. See if you can move the lever on the transmission freely from position to position. N would be nice. Now, will wheels turn.
2. Park is accomplished by a pawl inside the transmision. it may taae a bit more force to release than the cable leverage will allow. Parking down hill against a stop can do this. Carefully apply some force, with the wheels in the air, hand brake off and see if that will disengage the pawl. I've heard tales of busting the pawl in other critters. Bye, bye Park position.
If the differential is an open unit, turning the wheels will do nothing. But, a drive shaft disconnect, just might release some torque and allow the pawl to disengage.
Carl
Old May 25, 2015 | 04:13 PM
I'll try that in next few days. Should the circular flange on the back of the auto turn freely normally if in N?
oddly tho the 85 model the engine and transmission was extracted from did not have this problem, its only since I bolted the link between the auto and the shaft in the 74 body that it has occurred.
~ cheers
Old May 26, 2015 | 09:18 AM
JagCad's Avatar
Yes. N is a complete disconnect.
Carl
Old May 30, 2015 | 03:49 AM
doesn't seem to be much range oif movement, but should there be?
Old May 30, 2015 | 05:57 AM
ha! took some time to remove the link between the gear stick and the auto but once it was off i was able to attach another level on the switch and change to what i assume is neutral and she rolled. so its something to do with the gear lever linkage or getting stuck in Park...?
Old May 30, 2015 | 08:09 AM
Doug's Avatar
I wonder if the cable is seized or kinked?
Yes, the pictures suggest that the trans linkage is moving enough.
The transmission will lock in "P" and will roll with any other position selected. In other words, with the engine off, you could roll or push the car with the transmission in R-N-D-2-1 and the car would roll. Only in "P" is the transmission locked
Old May 30, 2015 | 08:11 AM
Doug's Avatar
Or perhaps the cable isn't securely mounted? The cable casing should be attached to a bracket on the underside of the transmission tunnel. If it has come loose then the inner cable might not move in-out far enough to properly operate the linkage on the side of the transmission.
Old May 30, 2015 | 09:28 AM
JagCad's Avatar
I suspect the swaging on either end of the cable that secures the housing has failed.
The result is that the cable within the housing doesn't move, only the housing. Been there. Luckily in my driveway.
Solution: replace the cable. I got what was described as an improved version from Johns cars in Fort Worth. .
Beats a crunched pawl inside all to pieces....
Joke bodge: Cut a hole on the pan. attach a rod to the lever on the trans. skip 1/2 the monkey motions. Just joking....
Carl
Old May 30, 2015 | 11:04 PM
using the lever on the gear box I can get 5 unique positions, but none of them produce a 'lock and rock' position as it was doing before........
Old May 31, 2015 | 09:26 AM
JagCad's Avatar
Cable!!!
1. Swaging failure.
2. Not securely clamped.
Good new. Trans is good. Only issue remaining is cable/shift tower function
Carl
Old Jun 1, 2015 | 06:37 AM
just a few more picts, still puzzling me
gear stick itself is securely fastened .. not sure about the cord into the transmission tunnel.
the different in positions obtained manually by the gear lever and those obtained by using the shift stick itself are dramatically different. surely the shift stick should obtain the full same range of motion that is manually obtainable??
pushing the lever to far left
pushing the lever to far right
changing gear stick to 1st gear
taking gear stick into park position
Old Jun 1, 2015 | 06:39 AM
by 'swagging failure' you mean that that the hydrollic motion must take place within a cable rigidly held in place (securely clamped) to effect the range of movement fully?
Old Jun 1, 2015 | 08:13 AM
Doug's Avatar
The cable *housing* must be secured and held stationary. If not, the cable itself, inside the housing, won't have full range of movement
Old Jun 14, 2015 | 11:21 PM
indeed was the bolt in the transmission tunnel, missing, once attached i have with much profanity and insanity tries to reattach the gear cable end to the lever on the transmission,
its always out by an inch and the tightening or loosing of the locknuts by the gear stick seems to change effect each time,
the motion of the gear action seems to change from straight to curved to up and down... loosing mind ... any suggestion.. feels like shifting sands..
philwarner
28
Jul 11, 2017 10:21 AM
jluckcuck
Nov 6, 2015 07:49 AM
millertic
Sep 30, 2015 08:11 PM
Bigvettefreak
Sep 28, 2015 03:03 AM
