Locking problem
Old Apr 4, 2021 | 10:59 AM
Huat's Avatar
Default Locking problem
Hi everyone
I am having locking problem with my X300 XJ6. I googled and there seems to be many people facing the same problem but there rarely anyone updating the solution.
What happened to mine was that I realised my remote fob isnt working. First I thought was the battery, so changed the batteries, but didnt solve the problem.
Then I suspect the need to reprogram the fob using the valet button. When I pressed the trunk release button, it didnt work, so is the door lock button, putting gear to drive also did not auto lock the doors. I thought was the valet button accidentally pressed, but I use the key to unlock the trunk also did not deactivate valet mode if it is activated. I tried using key to lock and unlock the door twice method mentioned in forum did not solve the problem as well.
Next, I realised that using the key to lock the car, will never lock the other doors.
Then I checked on all passenger doors, the front passenger and rear left door can be lock and unlock by manually pressing the door lock pin, and unlocking by pulling the door handle. Only for the rear right passenger door behaving oddly, the door pin will never go down when I pressed it down, it jumps back up and the door will not lock (video attached)
I hope anyone can tell me the possible reasons for the problem I am encountering. I really hope the SCLM is not dead...
Please help...
Thank you.
File Type: mov
Old Apr 4, 2021 | 11:43 AM
Hello,
I think you have posted in the wrong section. This is for the Series 1, 2, 3 Jags.
You want to post here:
https://www.jaguarforums.com/forum/xj-xj6-xjr6-x300-26/
Members there will be better able to help you.
Old Apr 4, 2021 | 12:20 PM
Huat's Avatar
Originally Posted by LnrB
Hello,
Oh so sorry about that, was overly tired from searching for solutions.
verdugo
May 18, 2021 07:04 PM
XJ6Aficionado
Jun 23, 2017 11:30 AM
tibam13
Feb 21, 2015 10:23 AM
Rhett
Dec 20, 2014 12:00 AM
AJRK
Mar 30, 2012 03:42 PM
