This mysterious Brown and black homeless wire...
Old Sep 23, 2019 | 12:31 AM
Coreybak22's Avatar
Default This mysterious Brown and black homeless wire...
Corey /Nashville/ 87 xj6 series 3, one hundred fifty thousand miles ,
So the wire to thats brown with a black tracer coming off alternator and I believe the diagram in my manual showed NB as color of wire and in skematic the wire is listed as fldg, so I know this goes to white through the failure,indicator light and to energize coil ect. Ect.,but where is that?? Is this what I do? Or should I put it on the +12v hot point in front firewall on LH side. Would love to know what it does and why can't I start car? No crank, and I also reattached a the temp sensor which was disconnected, can this be a problem that would cause a no spark/fuel?lastly , where do I put the brown and freaking black wire????
Corey
Old Sep 23, 2019 | 05:01 PM
worzella's Avatar
Hey Corey
Not much to add about wire but add a picture
As far as figuring out spark an fuel check out the pinned sections at the start of the forum. There are several super detailed step by step debug procedures to *** every section of fuel and ignition sys
My 86 SIII was a non runner and I used these docs to figure out ignition was fine but fuel pump was the culprit
One step at a time!!
Old Sep 23, 2019 | 07:39 PM
Doug's Avatar
The brown/black at the alternator wraps around the front of the engine, drops down into the area of the distributor and p/s pump, and then even goes to a multi-pin connector on the RH inner fender, down low. From there it goes into the cabin and to the alternator warning light
No.
The brown/black wire operates the alternator warning light, which provodes the resistance need to 'excite' the charging circuit. In and of itself this wire will not cause a 'no start' situation. However, if disconnected the alternator won't charge (or won't charge at low RPM) so the battery will not be getting charged
No crank,
This should help
Engine Will Not Crank Checklist
if it was the single wire sensor for the dashboard gauge then, no, it wouldn't cause a fuel or ignition problem. If it's the two wire sensor for the fuel injection computer, yes, it would cause a fueling problem if disconnected. In fact, it won't run at all if disconnected
Are you asking where on the back of the alternator does it go? If so, look for a vacant connection point on the back of the alternator
Old Sep 23, 2019 | 11:56 PM
Coreybak22's Avatar
Default No I didn't run it to power point!!
Haven't had time today worked on zero turn I just bought instead, but I'm sure glad I was these fun facts , in the morning I'll run the wire that is hanging out of the alternator still which is brown/black or NB and run it to right spot and tell me more about the fuel pump wires or the connector,
Corey u
Old Sep 23, 2019 | 11:58 PM
Coreybak22's Avatar
Default Sorry (I read these) not I was
Sorry kinda tired it's been a long one!
Old Sep 24, 2019 | 12:11 AM
Coreybak22's Avatar
Default Sorry also,
I meant the two wire sensor wire u forementioned, where? And color of wires coming off of it?
Old Sep 24, 2019 | 02:20 PM
Fraser Mitchell's Avatar
All UK cars used the colour codes as outlined here. AFAIK it was established by Lucas.
https://www.autoelectricsupplies.co....ew_order_2.pdf
Old Sep 25, 2019 | 12:12 AM
Coreybak22's Avatar
Default That was helpful
I at least determined the wire that is disconnected, it's the NB alternator battery sensing lead , and it goes to the warning light via a retstor , only resistor I can think is ballast but I took off, ( still not sure if it's the same as negative coil lead,if u were to connect it to lead it seems as if the circuit would close and my coil and fuel may come back, I dunno, man I'm over it for today
Corey
Old Sep 25, 2019 | 07:02 AM
Doug's Avatar
I at least determined the wire that is disconnected, it's the NB alternator battery sensing lead , and it goes to the warning light via a retstor ,[/ only resistor I can think is ballast but I took off, ( still not sure if it's the same as negative coil lead,if u were to connect it to lead it seems as if the circuit would close and my coil and fuel may come back, I dunno, man I'm over it for today
Corey
Corey, the NB wire doesn't have anything to do with the ignition coil and nothing to do with 'ignition' in terms of starting the engine. Nor does it have anything to do with the fuel pump.
The brown/black at the alternator wraps around the front of the engine, drops down into the area of the distributor and p/s pump, and then eventually goes to a multi-pin connector on the RH inner fender, down low. From there it goes into the cabin and to the alternator warning light.
If the engine won't crank, here is some info
If the engine cranks but won't start, more info:
ENGINE CRANKS BUT WON'T START
If the fuel pump isn't working:
Fuel Pump Circuit Checklist
Old Sep 25, 2019 | 07:13 AM
Doug's Avatar
The temp sensor for the fuel injection is on the water rail, third position back. It has black and blue/orange wires
Old Sep 25, 2019 | 11:19 PM
Coreybak22's Avatar
Default So found other NB
But I hooked it up and my indicator went out on dash for battery and my warning lamp but still no prime or fire, the wires on ignition are my next thought and yes I've checked the inertia switch , I have a click back in the trunk which to me would solidify that power is trying to go back there in boot but still in a conundrum, I'm gonna look at wiring diagrams now , thanks
Corey
Old Sep 25, 2019 | 11:22 PM
Coreybak22's Avatar
Default So found other NB wire
Corey
Colfod
E type ( XK-E )
May 11, 2018 06:13 AM
northwestjagxj6
Mar 11, 2015 05:45 PM
Jagxjs
Jan 20, 2013 07:25 PM
Vee
Jun 10, 2010 12:56 AM
sempaipaul
Jan 14, 2007 02:25 PM
