Need help timing 75 xj12
Old Mar 19, 2009 | 02:39 PM
mickflick777's Avatar
Default Need help timing 75 xj12
hi....
i just rip apart a 75 xj12 because i had no comperssion on cylinder 3.
i took off the head and found out that the valve seat fell down which
made the valve stick open. After i get the head back from the shop
i need to time it. i was woundering if you can help me.
thank you
Old Mar 19, 2009 | 03:19 PM
JagtechOhio's Avatar
The best way to do that job is with the factory tool to set the position of the camshafts before you remove a cylinder head, I think you need a camshaft setting gauge and a factory shop manual.
Old Mar 19, 2009 | 09:48 PM
the thing is that i dont have that tool
and the head is already off...
Old Mar 19, 2009 | 10:30 PM
Yeah, I already knew that.
dsnyder586
Dec 29, 2024 07:39 PM
Wolfy
May 28, 2024 08:06 AM
PMKimpton
Aug 3, 2019 08:22 PM
philwarner
Sep 5, 2015 10:05 AM
