numb-nuts mistake; rear door latch
Old Oct 12, 2015 | 09:12 PM
Curt Lee's Avatar
Default numb-nuts mistake; rear door latch
ever since I brought the '74 home, I've had to open the front door, reach in and open the back door from inside because the outside handle doesn't work... the other day, mucking about, I found a small rod sticking out of the door just above the latch and flipped it back and forth.... of COURSE, NOBODY had "child proof" door latches way back in '74!... stupid me. I forgot to flip it back and shut the door before it dawned on me that THAT was the only way I had to open it. BLAST and DAMNATION. I'll have to strip the door panel out from inside and actually FIX this problem that USED to be just a nagging nuisance....
Old Oct 12, 2015 | 10:30 PM
LOL I don't feel Nearly so dumb now about the stupid thing I did this evening!
Just when you get to thinking you're pretty smart, these cars shovel on some humbling experience that makes you completely reassess your worthiness.
Old Oct 13, 2015 | 10:25 AM
JagCad's Avatar
LnrB:
Not going to tell, huh!!!!
It will take a while for me to top my dumbest. Jaguar up on ramps.
Tracking no brake light issue. Took it out of park to track light function.
Zoom backwards. Door hyper extended by hitting parked Jeep. Saved me!!!
1. No chocks on rear wheel/s !!!! Why, I have no...
2. Hand brake did not hold? More to check out.
The little stripe of primer on the Jaguar's door reminds me to
be careful......
Carl .
Old Oct 13, 2015 | 12:05 PM
Well, if you insist, Carl, but I really don't qualify under the title of this thread.
I was making a retainer to keep a hose out of the whirly bits. It had to be Just Right or it wouldn't do the job. After working on it for an hour, getting *Very* frustrated a few times, almost losing my temper and calling down evil on the whole thing, and Finally finishing it up, I discovered I made it too long and the hose was going to be among the whirly bits anyway.
So this morning before breakfast I had to do it all over again. It's right this time.
Old Oct 14, 2015 | 07:37 AM
amaezing's Avatar
Ain't this the truth
Old Oct 14, 2015 | 08:48 AM
Doug's Avatar
Phhhffttt!
Is that all you got? Rank amateur. That little flub barely rises to 'mistake' level. It's miles away from 'boneheaded move'
One time, years ago, I misjudged and drilled a hole right thru the trunk lid of my Jag! I rushed the car to a body shop and begged them to fix it right away so as to put an end to the humiliation. If you have to pay someone else to fix what you've done, and swear them to an oath of silence about the matter, *that's* when you know you've pulled a boneheaded move !
Old Oct 18, 2015 | 02:06 PM
Curt Lee's Avatar
well; I decided to reinstall the dash and have a look at the door latch problem... the dash is done, more or less; there's still the covers under the dash and some other fiddly bits to attend to, but that damn door latch... first off, how in the daylights do you remove the door panel? two screws in the bottom of the pocket, but it doesn't shift at all... ANYWAY, the back upper corner of the panel was loose, so I simply pulled it down and got a look inside. The offending pin, the child safety latch, is at the top of the latch in the upper rear corner of the door opening, and it simply shoves back outward so the door will open from inside... I can't address the outside handle until I figure out how to properly remove the inner panel. And, as a bonus, since I had the rear seat bottom out, I was rewarded with the sight of two new projects to attend to.... both pans under the rear seat are rusted through. Argh. I'd have done these when I did the front floors if they'd been obvious.
Old Oct 18, 2015 | 06:25 PM
I've only taken off the front liner (which was a Huge PIA) but I'm thinking the rear should be very similar if you have a Series 2.
The door cards are loosened like all other door liners I've ever seen. There are "securing clips" around the perimeter of the liner. One carefully pulls these out of the door one at a time, being careful not to rip them from the liner (ask me how I know this).
Slip a putty knife or thin screw driver blade along the crack until you find a clip; the rear edge is probably easiest since it was loose anyway, and you might even be able to see another clip.
You'll have to take the inner latch handle off and the ash tray.
The screws in the bottom of the pocket only secure the pocket to the liner.
I hope that gives you an idea where to start at least.
Old Oct 19, 2015 | 05:29 AM
Richard_gib's Avatar
On my sIII sov, I removed the screws from under the arm rest thingy (I think one of them was under the light lense). Then the said armrest slided backwards half an inch then lifts off to reveal the big screws holding everything together. still had to do the popping of the push clips as Lnr described too. This was on the front passanger door, but I think the rear will be similar (maybe???)
Old Oct 19, 2015 | 05:42 AM
o1xjr's Avatar
Once you remove the screws from the pocket ,tap it upwards as it has pins that go into slotted holes, I know I removed a series 3 pair today to fit to my series 1.
And remove your window winder handle(make sure the window is up first so it doesn't block the locking mechanism.
numb-nuts mistake; rear door latch-dsc_4435.jpgnumb-nuts mistake; rear door latch-dsc_4451.jpgnumb-nuts mistake; rear door latch-dsc_4453.jpg
Old Oct 19, 2015 | 05:54 PM
Curt Lee's Avatar
I WISH mine had manual windows
Old Oct 19, 2015 | 06:02 PM
amaezing's Avatar
Don't say that. There's something slick about pulling up and the window going down without watching the persons head and body bob up and down.
Its a jag baby!!
ZenFly
71
Nov 9, 2015 10:04 AM
WhiteTardis
Oct 21, 2015 09:54 AM
Jumpin' Jag Flash
Oct 16, 2015 04:25 AM
Jeronimo770
XK120 XK140 XK150
Oct 13, 2015 11:34 AM
philwarner
Oct 13, 2015 09:38 AM
