Oil cooler hoses
I知 putting oil cooler hoses on my recently purchases 1984 Jaguar XJ6 and I知 wondering which order they go in. The front by the rad is obvious but where they connect by the oil filter is unclear which one goes where??
As far as flow matters, it won't matter which direction it goes thru the cooler. I believe you will find that if you are using original equipment, One way, They will just drop in easily and looks smooth. The other way, they look tangled. Lubricate the "O" rings liberally during install.
Thank you.
Larry Louton
Thank you.
Larry Louton
