oil gauge reading off scale
Old Mar 30, 2023 | 11:51 PM
mickvic's Avatar
Default oil gauge reading off scale
Hi replacing the oil gauge in my series 2 as the one there was from a 420 and it didnt really work.
Got a good second hand (i believe) got it plugged in and turn the ignition on and the gauge just slowly runs to max plus to the right.
Start the engine no change.
Looks like the wiring is connected right, at sender and the gauge, and the oil pressure warning switch , gauge has two green connected to one side, and white brown to the other. It did have a black earth connected to the bracket at the back not sure what thats for ! .
Any ideas folks?
Old Mar 31, 2023 | 01:18 AM
yarpos's Avatar
Only thing that springs to mind is that if the original gauge unit was not correct , then it may have an oil pressure sender that was also not correct to match. You may just have a mismatch.
When you pull the wire of the sender does the gauge go back to zero? just to rule out a wiring fault, as its behaving like the sender lead is earthed.
Old Mar 31, 2023 | 01:40 AM
mickvic's Avatar
Yes when I pull the wire off the sender the gauge goes back to zero ignition on engine not running
Old Apr 1, 2023 | 04:47 PM
yarpos's Avatar
I'd be looking at the sender then.
Old Apr 1, 2023 | 05:26 PM
The Mekon's Avatar
I have a couple of used units if you cannot find a new one. I can test them before sending.
Old Apr 1, 2023 | 08:33 PM
Jagboi64's Avatar
There are 60 psi senders and 100 psi senders, so you need to match them to the gauge.
Old Apr 2, 2023 | 10:15 PM
mickvic's Avatar
yes that would be good, series 2 unit would be great if working. what sort of dollars ?
Old Apr 3, 2023 | 08:55 AM
Aarcuda's Avatar
Either the sending unit or the wire coming off it is shorted to ground
Old Apr 12, 2023 | 05:11 AM
mickvic's Avatar
I got a new sender....gauge still going off scale ignition on. The was a black wire which was attached to the back of the gauge...touched that on the gauge, there was a spark...now none of the gaged work at all, temp battery charge whatever...hmmmmm . The car does start though
Old Apr 13, 2023 | 11:13 PM
mickvic's Avatar
Blew a fuse ok...too many random wires going nowhere on this car!!! So with new sender yes gauge is going off scale ignition on....and if i earth the wire to the sender ignition on same thing happens. Ran an independent wire from sender to gauge yep zips off the scale phew
Old Apr 15, 2023 | 02:21 AM
yarpos's Avatar
Sounds like its acting more like an oil pressure switch than a sensor that drives a guage. If it was switching an oil pressure light this is what you would expect , low resistance with engine not running and ignition on, so your oil light comes on. Then high resistance/open circuit with the engine running so the light goes out.
If you have a multi meter you could check what the sensor is doing in both cases.
Old May 14, 2023 | 07:15 PM
xjtom's Avatar
I'm guessing you have a series 1 xj6 buy your car list?.....the wiring should be from sender> Black/ brown stripe to oil press/warning light...oil press/send White/brown trace to gauge, green powers the dash all instruments...if you have a different setup let me know what you have & i'll post the info or message me, i'm in Sydney
Old May 14, 2023 | 07:24 PM
xjtom's Avatar
instead of an edit>> if you have the S1 printed circuit dash, the black is terminal 3 for the dash lights earth,...green is for terminal 7 from fuse #1...oil press/ sender white/brown is terminal 6
Old May 15, 2023 | 03:02 AM
Peter3442's Avatar
https://www.jaguarforums.com/forum/m...2/#post2576146
​​​​​​Comment 11 of the link above and the attached 'Gentleman's guides' explain how the gauge and sender work and how to test and calibrate them. It does sound as if your sender is actually a switch for a warning light.
Old May 15, 2023 | 05:09 AM
mickvic's Avatar
Yes, series two. Looks like black brown to warning light, white brown to gauge and down to the sender, two green wires to gauge.
INDYJAG-84
Mar 21, 2017 09:33 AM
Dale Dunn
Mar 20, 2017 04:44 PM
thedugger1
Feb 19, 2016 09:00 PM
mrtalkradio
Jul 18, 2012 09:00 AM
mannymux
May 20, 2012 02:19 AM
