Oil supply for my turbo
Old Jul 21, 2009 | 04:23 PM
1985jag's Avatar
Default Oil supply for my turbo
there seems to be oil feed lines going to my heads if i am correct could i tap into them send oil to the turbo then to a cooler then to the heads? or any better/ more accurate ideas?
Old Jul 21, 2009 | 05:47 PM
JagtechOhio's Avatar
Default Oil pressure port
Greetings,
I know nothing about the project you are undertaking, and a fair amount about the stock engine you are modifying.
That scares me to do anything to reduce camshaft oil feed. What about just using the hole into the gallery for the oil pressure sender? RH side of engine, just in front of the starter. It's mounted on an aluminum block, which may already have an additional (blocked) port in it. If not, I'm sure you could figure out a way to "T" or relocate the oil pressure sender. You're probably going to want to use a mechanical gauge anyway, right? The stock electrical senders are somewhat inaccurate, and unreliable.
Old Jul 21, 2009 | 07:22 PM
Thermo's Avatar
Veteran: Navy
1985Jag, you don't want to run oil components in series with each other. Like was mentioned by JagTech, you want to run the oil for the turbo in parallel to the rest of the motor. Then all you are doing is controlling the amount of oil to the turbo. More oil to the turbo is good for the turbo, but if too much, can starve the rest of the engine, leading to failure and vice versa. This is where selecting the correct size fittings and size lines is going to be critical.
Old Jul 21, 2009 | 07:26 PM
Dry sump/ pump would be the way to go, eh wat?
Old Jul 23, 2009 | 03:03 PM
1985jag's Avatar
Default eh i dont know what im doing when it comes to turbos!
never installed one on a n/a vehicle. so i will use the sender and yes a mecanical gauge will replace existing components return to the pan? or send to a cooler then return to where?
Old Jul 23, 2009 | 03:37 PM
Please reread my first post, and you're welcomed for both.
Old Nov 10, 2009 | 09:49 PM
redjag8841g's Avatar
Dont most manufacturers suggest that you mount oil lines in the oil pan? One a send line, the other a return. Just a thought.
hafren
23
Jan 3, 2025 11:26 AM
Tim Goz
Sep 17, 2015 09:11 AM
1964Daimler
Sep 9, 2015 11:20 AM
AL NZ
Sep 4, 2015 08:39 PM
XFR_Gold
Sep 2, 2015 12:24 PM
