View Poll Results: What's a good color for a XJ6
Red
55.56%
White
33.33%
Blue
33.33%
Purple
11.11%
Multiple Choice Poll. Voters: 9. You may not vote on this poll
PLEASE help NOOB with 85 XJ6 issues
Old Feb 6, 2019 | 05:39 PM
Fraser Mitchell's Avatar
See if you can get one of these, (or a pdf equivalent).It's a Mine of Information.
https://www.ebay.co.uk/i/233102720786?chn=ps
Also have a read here:-
Fuel injection and the Jaguar XJ6 4.2 Series 3 / AJ6 Engineering
It takes you through the whole EFI system and what can go wrong. Unlike systems of today, the Lucas/Bosch L-Jetronic EFI system is analoge, so forget about digital and fuelling maps, they don't exist here !
The fuel pump is kept running via the fuel pump relay and this is supplied with volts, (except at starting), via two small contacts in the mass flow meter. Over the years these lose their springiness and can fail to make contact, so the car starts and when the ignition switch is returned from the "Start" position, the supply ceases and the engine stops. Other thing is to clear out the fuel tanks and clean the filter gauzes, plus replace the main fuel filter in the engine compartment.
The whole EFI system relies on pulses taken off the back of the coil. Without these the EFI will not fire the fuel injectors. As others have said, the Cold Start Injector eases a cold start, but is not totally essential you just have to crank the engine more.
Old Feb 6, 2019 | 09:28 PM
Doug's Avatar
Originally Posted by Yellow series3
, go to NAPA and get the assorted box, read the chart Carl mentioned on the removable lid and install new ones of the right amperage .
USA owners will want this:
Fuse Conversion Chart
Old Feb 6, 2019 | 11:28 PM
Yellow series3's Avatar
Wow, who knew (except Doug and Kirby Palm)? I am definitely going to print that out and tape it to the page in the manual where it lists the fuses. I always thought they used mighty big fuses for the circuits they were protecting. Thanks for this valuable information.
Jeff
Old Feb 7, 2019 | 07:25 AM
yachtmanbuttson's Avatar
I agree! That chart is an eye opener. Who would have thought.
digimurda
Feb 12, 2021 08:03 AM
cbryantjr85
Oct 21, 2016 03:46 PM
richardjay
Jul 5, 2015 04:50 AM
driftr319
Jul 29, 2011 12:30 PM
swift707
Dec 17, 2009 11:00 AM
