rear end clunk
Old Jul 18, 2015 | 06:43 AM
Joey T's Avatar
Default rear end clunk
hi all: When I slow to a stop and drop down to first gear I get a clunking noise in the rear end. I'm not sure if it's a u joint or something worse. Any suggestions would be greatly appreciated. '85 XJ6
Old Jul 18, 2015 | 06:57 AM
Jose's Avatar
check all rear suspension bushings, and the transmission mounts, there's two, one on each side of the transmission.
Old Jul 18, 2015 | 07:25 AM
Also, release the transmission kickdown cable about 1/2 a turn. If it is just that bit too tight the trans will cause a "clunk" as it goes into 1st gear on the over-run.
The 4 bolts that hold the centre section (some call it the pumpkin) in place are known to loosen with age. Access is NOT good, but with patience is do-able, and they WILL cause a clunk, but it is usually on take up as well as backoff.
Centre bearing worn, however a vibration is usually an associated feeling.
Old Jul 18, 2015 | 07:29 AM
Jose's Avatar
what centre bearing Francis? do you have a drawing?
Old Jul 18, 2015 | 07:39 AM
Doug's Avatar
Item #6
Tandem Propshaft - Parts For Series III Saloon | Jaguar Heritage Parts UK
Old Jul 18, 2015 | 07:48 AM
Doug's Avatar
All great suggestions so far .
What's your idle speed? If too high you'll get a downshift clunk as you roll to a stop.
How many miles on the car?
With miles you can get a 'stack up' of wear-induced free play in the transmission output section, driveshaft splines, and differential. Not necessarily anything to worry about but it *can* make for some clunks. The fact that the old BW trans is not known for being glass smooth contributes.
Old Jul 18, 2015 | 08:47 AM
JagCad's Avatar
Doug:
Not like the Dynaflows of decades past, huh?
Carl
Old Jul 18, 2015 | 09:30 AM
Doug's Avatar
Originally Posted by JagCad
Doug:
Carl
Nope
Old Jul 18, 2015 | 10:48 PM
Saemetric's Avatar
By releasing, do you mean shortening or lengthening the outer cable?
Old Jul 19, 2015 | 04:49 AM
Shorten, as in turn the nuts "clockwise", so 3 flats = 1/2 turn in my language.
Old Jul 20, 2015 | 07:03 AM
amaezing's Avatar
U-joints can be tested by; at a stop go forward a few feet then backward a few feet. a couple times. If there is a clunk at the beginning of each then it's a u-joint. if not then chances of u-joint are slim to none. This works about 95% of the time.
Old Jul 20, 2015 | 07:34 AM
Doug's Avatar
How does this method differentiate the U-joints from any of the other things, mentioned above, that can cause a clunk?
Old Jul 20, 2015 | 09:26 AM
amaezing's Avatar
I would think that it would narrow it down. if a bolt got loose then it would usually only be noticable in one or the other way. the u-joint souds both ways. like I said.. most of the time... there are exceptions of coarse.
Old Jul 21, 2015 | 06:09 AM
Joey T's Avatar
idle speed 5 in gear 8 to9 at idle tried the u joint test it passed. ill have to get under it to check bushings and mounts
GordoCatCar
Jan 2, 2017 01:10 PM
Thang Nguyen
Oct 12, 2015 01:25 AM
RaceDiagnostics
Sep 7, 2015 07:28 AM
XKR-NC
Sep 4, 2015 08:23 AM
obwoodie
Sep 3, 2015 07:45 PM
