Removing rear subframe
Old Oct 27, 2019 | 03:59 AM
Rudy Mensink's Avatar
Default Removing rear subframe
Hello Jaggernauts;
My project 'Series 2 with AJ16 and ABS'is going slowly but steady on ;-) , heve recently bought a complete rear-subframe from a 1993-XJS .
Now i want to completely replace the rear-subframe, but before i start a question: : how is the subframe mounted at the body, 2 rubber joints at the front and 2 behind the subframe, or do i missed something?
Thanks again for your support, reg., Rudy
Old Oct 27, 2019 | 07:46 AM
Fraser Mitchell's Avatar
You're spot on. There are two mounts each side at the back of the wheel arch. Then there are the radius arms that attach to the lower wishbone, so don't actually contribute to the mounting of the subframe, but have to be removed before the subframe can be dropped.
Old Oct 27, 2019 | 09:34 AM
Hi Fraser, yes, I thought so. Thanks a lot, greetings, Rudy
Old Oct 30, 2019 | 11:29 AM
JagCad's Avatar
+ drive shaft, brake lines, mufflewrs !!!
Carl
Old Oct 30, 2019 | 02:15 PM
David_h's Avatar
There is a lot of good info on R&R including some YouTube videos. I just took mine out two days ago to rebuild the calipers since the pistons were not retracting. I am going to retrofit to a remote bleed kit; which you may want to investigate.
Old Oct 31, 2019 | 09:54 AM
yachtmanbuttson's Avatar
How many inches did you have to raise the back of the car in order to get the complete rear end assembly out?
Old Oct 31, 2019 | 04:04 PM
David_h's Avatar
I allowed 18” out back but it was not enough because of the jack. So it came out the side.
Old Nov 1, 2019 | 08:02 AM
Doug's Avatar
As mentioned, if you take it out from the side the car doesn't have to be all that high, although I never actually measured. I've seen pics where some guys have the back of the car a mile high to remove the rear suspension. Scary !
Old Nov 1, 2019 | 08:16 AM
A nice photo that shows the two mounts in postion at the back of the wheelarch, and the single stud on each of them that secures them to the subframe.
Old Nov 2, 2019 | 03:06 AM
o1xjr's Avatar
As Doug says, out from the side is easy. I probably went higher than I needed to the first time.
JayJagJay
Sep 26, 2019 01:31 PM
rowland
Jul 14, 2015 12:56 AM
jaypee_6680
Jun 23, 2014 07:15 AM
