Replacing rear studs
Old Nov 24, 2011 | 09:16 AM
S1013's Avatar
Default Replacing rear studs
1982 XJ6 how do you replace the rear studs? Can't tell if they thread in or are pressed in? All the parts info I have is no help. My best guess is go under the "shield" and grind the head of the back side and hope they thread out. Then find a 1/2 x 20 stud to thread in. Appreciate any info on this - Thanks
Old Nov 24, 2011 | 08:59 PM
motorcarman's Avatar
I answered this on the Jag Lovers forum but YES the staked part is ground off with a cut-off wheel and the stud can be 'double-nutted' to remove the old one (or just use locking pliers)
I double-nut the new stud to install and tack weld the back of the stud to the hub.
The part number is C13365.
I keep them in stock for replacement. It might be good to keep one in the glove cubby for future use.
bob gauff
Old Nov 27, 2011 | 02:07 PM
S1013's Avatar
Default Rear Studs
Thank you for the info, I already have it done!
philwarner
Dec 6, 2021 07:13 AM
AdeV73
Sep 21, 2015 10:29 PM
Sprayall
Sep 3, 2015 07:49 PM
Andrew McVey
16
Aug 27, 2015 07:21 PM
dpappyp
Aug 27, 2015 06:31 AM
