Seeking submerged pump mount
Old May 30, 2021 | 01:10 PM
4catstudio's Avatar
Default Seeking submerged pump mount
On draining my defective right tank I found the retained submerged pump mount and fuel feed assembly had been repaired by a previous owner and the welds were failing. It seeped fuel at the slightest provocation. My welder shop guy has spent no small amount of time attempting a repair but the metal is so thin it burns through. I am desperately seeking a good used piece, as it only comes with a submerged pump, which I don’t need. It’s the right hand version of the attached drawing from the parts catalog, mirror image of the illustration. I know I should post to the classifieds, and will do so as well.
Please PM if you have a spare.
Old Jun 1, 2021 | 02:21 PM
JagCad's Avatar
David Bboger everydayxj. In the Carolinas. Good guy. Lots of used good parts and some NOs.
Old Jun 1, 2021 | 02:38 PM
4catstudio's Avatar
Thanks for the suggestion.
‘I’d forgotten about him.
‘RichardinMaine
Old Jun 1, 2021 | 09:21 PM
Larry Louton's Avatar
Is that flange the same as the flange that holds the sending unit? find a tank and attach that in place of the old flange?
Thank you.
Larry Louton
Old Jun 2, 2021 | 06:47 PM
Allow me to correct myself, If a flange is needed, Find a old tank and cut out the flange of the sending unit big enough to replace the old flange. if you don't need a flange, Cut out the offending area. and weld in new patch. Fill with water to leak check.
Thank you.
Larry Louton
Old Jun 3, 2021 | 10:25 AM
4catstudio's Avatar
Default Solution
Every single breaker / yard / used parts seller blew me off. I suspect getting into an old fuel tank was too much trouble; can’t faul them I guess.
‘Anyway my welding shop came through for me; fabricated a replacement out of stainless at no small cost, but it’s worth it.
‘The astute will notice the addition of a second return/equalizer line inlet, as the car was changed previously to an external single pump.
‘Thanks for the advice; I have to go get a little greasy.
FrankieBoy
E type ( XK-E )
Oct 15, 2018 05:18 PM
ODtape
Jun 17, 2018 10:45 AM
ColeD
Jun 12, 2018 06:24 PM
Paulc732
May 27, 2015 11:32 AM
SableXJ6C
Nov 26, 2012 07:07 PM
