series 1 rear bumper dissasembly rusty nuts issue
Old May 11, 2018 | 01:50 PM
olivermarks's Avatar
Default series 1 rear bumper dissasembly rusty nuts issue
I'm trying to separate a complete rear bumper, but the two bolts that hold it all together behind the overriders were seized solid and after too much pressure one is now rotating, but I think I broke the anchor deep inside the overrider. Can't get a nut separator in there, should I drill out or is there an alternative way to undo?
Old May 12, 2018 | 06:07 AM
Robert Laughton's Avatar
I have the same problem. I hope someone has the answer.
Rob
Old May 12, 2018 | 06:25 AM
Jose's Avatar
you will have to find a way to slice the bolt, maybe a Dremmel tool or a cutting wheel. Are you referring to the overrider bolts? they always do that. In another car, I used a bumper bolt from the overrider thru the bumper.
Old May 12, 2018 | 09:19 AM
The BD.38811 part breaks loose and rotates when you turn the ufb.137 bolt, and the loop pf chromed steel in the overrider with hole in for socket makes access with a bolt cutter or cutoff wheel inaccessible.I'm assuming I'll have to drill it out unless I can find something to slide into the darker recesses of the overrider to lock the bd.3811 anchor so I can get enough torque on the bolt...
Old May 12, 2018 | 09:31 AM
JagCad's Avatar
Yeah, aka "captive" nuts. always deep in unaccessible recesses.
And drilling the stub is tough as it merely rotates rather than accept the bit!!
Decades ago, I bought a "retired" company car from my employer. Badly abused. So, I got a really good deal. The hood/bonnet had parted ways at speed. It had been hjeld to the hinges by bolts into captive nuts. A friend at a "black smith" shop helped me get the out and reestablish a connection of the hood/bonnet to the hinges. He found just enough room to wedge the nut and accept the drill. Once out welded in nuts just a tad larger. New bolts to fit and stronger than it was when it left Dearborn. The bonnet a bit scratched and burnt. but, I cleaned it up and the rest of the car and splurged on a pro paint job. From a boring white to Thunderbird red.
Carl
Old May 12, 2018 | 09:34 AM
JagCad's Avatar
In desperation. Drill the over rider from the finnish side. Lock the nut,. Drill out the stub. fill the hoe with a chrome plug. Or go old tech, a bolt with a chrome head all the way through. Nut now exposed on the back side of the blade
Carl
Old May 12, 2018 | 09:46 AM
Jose's Avatar
ok, try to clamp bd38811 so it doesn't move. if you don't want to scratch the chrome with a clamp, use wood under the clamp feet.
Old May 12, 2018 | 10:09 AM
You can't get anywhere near bd38811 with any kind of clamp as it's buried in the overrider. I think I'll have to bend up a piece of metal into a 'wrench' to slip inside the overrider, which is in good shape on the exterior with good chrome, so I can lock it and get a breaker bar on the UFB bolt...
Old May 12, 2018 | 10:11 AM
You can't get anywhere near bd38811 with any kind of clamp as it's buried in the overrider, which is currently attached to the bumper. I think I'll have to bend up a piece of metal into a 'wrench' to slip inside the overrider, which is in good shape on the exterior with good chrome, so I can lock it and get a breaker bar on the UFB bolt...
Old May 12, 2018 | 10:13 AM
Actually looking at the picture it's BD 32461 the overrider that has the captive nut in it. That must have broken off way back inside there.
Old May 12, 2018 | 10:15 AM
Actually looking at the picture it's BD 32461 the overrider that has the captive nut in it. That must have broken off way back inside there. It's time like this I wish I had an induction heater
Old May 14, 2018 | 07:58 AM
yachtmanbuttson's Avatar
Can you cut the head off of UFB.137, then grind it back so it's just a stud?
Old May 14, 2018 | 09:49 AM
JagCad's Avatar
One word !!!
Elegant.
Carl
Old May 14, 2018 | 06:11 PM
Jose's Avatar
yatchman just hit the lottery!
Old Sep 15, 2018 | 01:10 PM
Default I put a ring spanner on the head and drilled it out
A bit time consuming, but put a ring spanner over the head to stop it spinning and drilled out the head to release.
Old Apr 8, 2019 | 08:21 PM
For the record I have found a better method to release stuck over riders from the bumper.
First, prop the entire bumper up so the two side pieces are facing upwards. then pour 50% acetone 50% ATF into the two overriders and leave to soak in for a few days.
This may be enough to free up the hidden trapped nut deep inside the overrider. If you break off that hidden nut and it spins, a 3/4 inch short socket or better a 3/4 crowsfoot with a handle welded onto it at an angle so you can insert it will allow you to put more force onto the bolt against the trapped 3/4 nut to release it.
yarpos
Jul 27, 2016 01:21 AM
Tommahawk
May 31, 2010 03:12 AM
