Series ll Clock
Old Feb 15, 2021 | 08:45 AM
denis4x4's Avatar
Default Series ll Clock
I've sent my clock to two different shops and it is unfixable. Tried the usual sources to no avail and it cannot be converted to a quartz movement. Any other ideas?
Old Feb 15, 2021 | 09:49 AM
You might have to just put in a quarts clock and forget about converting the one you have.
I was pleasantly surprised to find the PO had done that already to Nix. As I had never seen an OEM clock, I have no idea if it's correct or not. Certainly it looks pretty good in the hole.
Here's a pretty good pic.
Old Feb 15, 2021 | 10:16 AM
Greg in France's Avatar
These people would be worth contacting:
https://www.clocks4classics.com/
this being an example of their kit:
https://www.clocks4classics.com/uplo...ctions__v7.pdf
or this
https://www.jaguarclock.com/
Old Feb 15, 2021 | 11:13 AM
Jose's Avatar
fit one from a X300, It is narrower than the Series 2 clock but you can fill the sides with black plastic strips from behind.
easy to connect with 3 wires: one for Ground, one for 12 volts, one for the dash lights.
and the most incredible thing is that it works!
Old Feb 15, 2021 | 11:25 AM
Jose's Avatar
the original console clock in a Series 2 XJ-6 looks like this:
Old Feb 15, 2021 | 11:41 AM
Jose's Avatar
here's the clock Jaguar used in all the Big and Small Saloons, E types, you name it, from 1955 to 1968. Historically they are decorative items, since they never worked, not even at the Dealer's Showroom.
Old Feb 16, 2021 | 09:16 AM
nileseh's Avatar
This listing is on eBay:
https://www.ebay.com/itm/Jaguar-XJ6-...e/143653361130
full disclosure, my listing. details ore on the eBay listing.
Old Feb 18, 2021 | 05:06 AM
Jose's Avatar
I found a second Series 2 clock in my parts hoard and it works! Amazing! The orange needle counts the Seconds, and the clock itself is the Quartz version of the KIENZLE clock of W Germany. I am refurbishing the cosmetics, from one clock to the other. The "pretty" one does not work, the "ugly" one works perfectly.
JaguarXKR
Jun 20, 2024 12:14 PM
82jaguarxj6
Apr 21, 2020 07:39 AM
jordanmc
Mar 1, 2017 09:47 AM
XJeej
Mar 8, 2016 09:08 AM
