Seven Pin Wire Challenge
Old Apr 6, 2021 | 08:51 PM
adenshillito's Avatar
Default Seven Pin Wire Challenge
my picture is blown out and so retracing my indicator/hazzrd links is not that easy.
four pins at top of the switch then three below, seven total, i name them clockwise in block 1 A, B C D and then clockwise in lower bock E F G.
my candidate wires green/blue, green another green/blue, green/red, green/pink, green/white and brown/orange
some of the identification in my wiring chart (choke solenoid???) makes me think it isn't close to right.
Old Apr 6, 2021 | 08:55 PM
""The final wiring that worked for Ben P., was as follows:
#1-Light green/blue wire
#2- Light green/white wire
#3- Light green/red wire
#4- Light green/green wire
#5- None
#6- Light green/pink wire
#7- green wire
#8- Brown/orange wire
i will try this found on line
Old Apr 6, 2021 | 09:19 PM
pin configure, but Ben's P's advice not certain of pin numbering, altho maybe guided by pin 5 being absent.
Old Apr 7, 2021 | 09:34 AM
What are you wiring?
S-2 window switches look like that on the back, I'm not aware of any others.
Old Apr 7, 2021 | 05:39 PM
back of the hazard switch / indicator ..
i think I have got it , tho not tested. the pin i was fixing's original was still stuff in the plug so following the list i posted from the replaced pin clockwise i think I have the wires back in order.
Old Apr 8, 2021 | 09:07 AM
OK, I was advised early on to not mess with the hazard switch as it was very delicate, so I've not used it nor had occasion to have it apart.
Old Apr 10, 2021 | 07:21 AM
having now done it I would say that is good advice.
SableXJ6C
Dec 16, 2018 11:23 AM
revauto
Aug 22, 2017 10:36 PM
njk1963
Jun 5, 2017 07:54 PM
virtue
Sep 24, 2015 02:20 PM
leaperjag
Mar 3, 2010 06:25 PM
