Speedometer
Old Jul 17, 2020 | 06:56 PM
Proquest's Avatar
Default Speedometer
Is there an hidden inline fuse for the speedometer? I swapped transducer and speedometer. It worked a month ago.
Old Jul 17, 2020 | 07:14 PM
LT1 jaguar's Avatar
Active Streak: 60 Days
If you have an XJ6 S3, look at fuse #4 in the main panel which is just to the left of the steering wheel behind the lower dash panel, there's a small access door. Both speedo and transducer work from that fuse.
Dave
Old Jul 17, 2020 | 08:41 PM
Doug's Avatar
No.
Do you have a trip computer and, if so, is it registering miles?
Old Jul 17, 2020 | 11:46 PM
Proquest's Avatar
Default 1983 series 3
Yes, I am sorry it is for a xj6 series 3 1983 with a trip computer. The computer is not reading speed either.
Old Jul 18, 2020 | 12:23 AM
Doug's Avatar
Well, the speedometer and the trip computer both take their reading from the transducer. If the fuse is OK...always check that first..... I'd suspect a broken connection somewhere along the line
Old Jul 18, 2020 | 03:24 AM
Andy T.'s Avatar
Fuse #4 also supplies the other gauges (tacho, oil pressure, volt meter, temp & fuel) so if the fuse were defective these other gauges would also not register.
Old Jul 20, 2020 | 07:16 AM
Proquest's Avatar
Default Working now
I hit a bump in the road and speedo and the trip computer started working. Will have to chase the wiring and grounds. Thanks for your ideas.
Old Jul 20, 2020 | 01:24 PM
JagCad's Avatar
Fiddle related
there on eacount,oso many...
Carl
Nathaniel Eckert
Feb 4, 2020 10:49 AM
pbuhler13
Feb 1, 2019 07:40 AM
yellowbug
Sep 24, 2013 08:12 PM
marvin1960
Aug 7, 2013 06:01 PM
in2town
XJ40 ( XJ81 )
Jun 24, 2009 05:22 PM
