Stromberg 175CD2 leaking
Old Nov 8, 2018 | 12:38 PM
Adrian L's Avatar
Default Stromberg 175CD2 leaking
Got a fuel leak from around the big jet on the bottom of the carb. Can I just unscrew this jet with the carbs still attached and replace the O-ring?, or do I need to disassemble the float bowl, etc?
Wish the car had SUs, because I could fix those in my sleep!
Old Nov 8, 2018 | 05:12 PM
rustfreemike's Avatar
Being a 71 I'm not sure if it's a plastic snap in plug with a metal cap (72 & 73 usually are) but if it is, don't try to pry it out or you risk breaking it. You can remove the fuel bowl easily enough if you're reasonably dexterous without pulling the carb - just the 6 straight head screws.. Then if it's the plastic snap in plug you can release the tangs that hold it in and push it out to replace the O-ring.
Old Nov 9, 2018 | 02:19 PM
Adrian L's Avatar
Interesting. So the brass jet actually stays in place when you remove the fuel bowl. Thanks for the tip.
Old Nov 9, 2018 | 03:43 PM
It should be just a plug on your car - not a jet. But it can be either a screw-in brass plug (it'll have a slot to unscrew if so) or a snap-in plastic plug with a brass cover (featureless). You can remove the fancier brass one without removing the bowl. Snapped a pic of both in the shop.
Old Nov 9, 2018 | 05:04 PM
Adrian L's Avatar
It was the screw in brass plug. Easy to remove but I took off the air cleaner to get better access. Rubber ring was pretty loose. It looks to be about 13/16" in diameter. Unfortunately none of the O-rings I have in stock will work, but I did order two carb rebuild kits last week for $50 and they're on the way.
Thanks again for the help.
Old Nov 9, 2018 | 06:14 PM
No problem. Nice that you have the far superior brass plugs. BTW for the archives... size of the plug O-ring is -114 which as you say is 13/16 OD.
Ol Blue
E type ( XK-E )
Jun 19, 2018 12:05 PM
ebrand
E type ( XK-E )
Sep 23, 2015 11:34 AM
pricebill
Feb 23, 2015 09:07 PM
Civicalized
General Tech Help
Sep 9, 2011 11:47 AM
lone_rngr
Oct 17, 2007 01:58 PM
