Success on stripping paint off Kents
I used Aircraft Remover paint stripper made by Kleen Strip. This is the blue can. I have used this stuff for over 20 years and always have some on hand. I globbed it on and let it sit about 15 minutes. That's all it took. I used a piece of 0000 steel wool and scrubbed lightly then rinsed. It was clean aluminum but there was a few spots of corrosion. I used a piece of red scotch brite and scuffed in the same direction as the factory mill lines and it cleaned off the corrosion. I used some Mothers Mag and Aluminum polish on a rag and it started bringing out a luster. Going to get a new Powerball and hit it hard. My old powerball fell apart from dry rot. This is just one wheel but wanted to do a test.
Well, not quite!!!
Unless sealed, they will corrode quickly. I have a rattle can on my shelf for that. I use it as a clear coat on other stuff.
Carl
Carl
Thanks for sharing the products and method. I normally have a dislike for the Kents up to the point of "what were they thinking", but seeing them in their native metal finished nicely has changed my mind. Looks very good.
oilstain
Sep 8, 2016 07:31 PM
pdxpete
Sep 6, 2016 06:21 PM
