Which Tank of Gas
Old Jun 17, 2009 | 12:41 PM
N3FOL's Avatar
Question Which Tank of Gas
With the tank switch in the IN position, which tank am I actually using? Left or Right? I have an 84 Jaguar XJ6.
Old Jun 17, 2009 | 04:33 PM
Walter1982's Avatar
on my 82 when the button is in I am using the driver side tank. with the button out, the passenger side.
Old Jun 18, 2009 | 09:45 AM
N3FOL's Avatar
Default Tank
Good info. I think I'll be able to remember this one .
Let me see...IN is left tank. OUT is right tank.
Old Jun 18, 2009 | 10:14 AM
CatLovr's Avatar
My 1980 4.2 XJ6 didn't have either sending unit working when I bought it. So, upon advice from a longtime jag mechanic, a valve conversion was installed that links the two tanks together and only one sending unit is needed. I leave the button out (yes, out WAS for the right hand tank) and ignore it. Cost for valve and install was about $400. Just something to consider down the road.
Old Jun 22, 2009 | 09:49 PM
Keith's Avatar
With the switch out, you should see the letter "R" on the drivers side of the switch, indicating Right side. If not, it may be worn away.
Old Jul 4, 2009 | 10:47 PM
Doug's Avatar
Originally Posted by freexjv12
hi fellas
i'm new here and to the whole jag thing, just been given a 1984 xj v12 5.4 its in fair to good nick. The present owner had fitted a new battery for me and had the thing fired up on two consecutive days and drove it about his garden. I went to pick it up and it fired, ran and as soon as the throttle was pressed gave up. I put fresh fuel in the right tank it took only 10ltr to fill. its showing as empty on dial. Is the right tank the reserve and smaller than the left i have the selector switch in the out position with the r showing. We flattened the battery trying to restart once it had stopped. Does the dial give an overall picture of the fuel situation or does it also switch between tanks when operating changeover switch.
Any help would be great.
Rich
Both tanks are the same size, about 12 US gallons.
Each tank has its own fuel level sending unit. The changeover switch is dual function: switches which tank fuel is draw from and also switches the sending unit
Rusty tanks are a common problem on these cars, especially if they have sat unused for some time. My gut feeling is thet you have a rust-in-the-fuel problem but of course that's only one possibilty. Removing the fuel filter and emptying the contents into a clean container might reveal important clues
Old Jul 6, 2009 | 11:22 AM
N3FOL's Avatar
Default Fuel Filter
Hello Freexjv12, I am not sure on your XJ12...but I think on my XJ6 '84, the fuel filter is located in the trunk area.
Old Jul 6, 2009 | 11:24 AM
N3FOL's Avatar
Now I think I'll be able to remember this orientation. Switch 'OUT' - right side tank. Switch 'IN' - left side tank.
Justinb
E type ( XK-E )
Jun 21, 2023 05:29 PM
bdboyle
Sep 16, 2019 05:58 PM
hkmcmast
Nov 29, 2015 06:56 AM
vwbusbits
Oct 13, 2015 03:43 AM
