Tap and Die Set for Use with Jags
Old Feb 7, 2023 | 08:41 AM
muttony's Avatar
Default Tap and Die Set for Use with Jags
I need to get a set for re-doing the IRS (for cleaning holes, bolts and nuts if required) and don't want to get a big set that doesn't work with the nuts and bolts used. I seem to remember some weird english thread types.
What type of set should I get. Is SAE good enough?
Old Feb 7, 2023 | 10:25 AM
Jagboi64's Avatar
Almost everything is SAE fine thread. The only Whitworth thread is the upper timing chain adjuster nut on the engine. If something goes into aluminium it will be SAE coarse, like some of the manifold studs into the head, but into steel or iron will be fine thread.
Old Feb 7, 2023 | 03:14 PM
The Mekon's Avatar
[QUOTE=muttony;2612040]I some weird english thread types.
Weird English threads? Offence taken - send this man to re-education camp to learn respect for ancient thread types!
Old Feb 7, 2023 | 04:46 PM
Fraser Mitchell's Avatar
I know the threads as UNF and UNC (Unified National Fine, and UN Coarse). Some electrical stuff from Lucas will also use BA, (British Association) for the smaller stuff.
Have a read: -
https://en.wikipedia.org/wiki/Unified_Thread_Standard
Edited
United should read Unified
Old Feb 7, 2023 | 06:14 PM
Jagboi64's Avatar
On older Jaguars, the SU carbs and Dunlop brakes are also all BA fasteners.
Old Feb 8, 2023 | 01:20 AM
Greg in France's Avatar
The differential to rear cage and the inner fulcrum dog bone fasteners are UNC. I think you will not need a tap and die set to clean those threads, just a good spray with brake cleaner, maybe some rust dissolver if needed, followed by running the bolts in and out a few times will do it.
Old Feb 8, 2023 | 12:10 PM
JagCad's Avatar
One can make a tread chaser. A crude tap. Use the bolt that fits. cut a groove perpindicular to the threads. Grind a chmfer on the front. run it in and out a few times with a light oil as alubricant. If you are fussy, use a vcumn on te opening afdter the chase.
Carl
Old Feb 8, 2023 | 09:25 PM
Carl
First mention I've heard of this in a very Loooong time, Carl.
On the farm when I was a wee lass, tools of this sort (taps, dies and thread chasers) had a habit of crawling off. My dad's brother (the Real mechanic of the outfit) used to do this quite a lot, make impromptu thread chasers, on the bench grinder.
As you say, it worked like a charm for bolt holes full of dirt, chaff and light rust.
Old Feb 10, 2023 | 05:39 AM
lickahotskillet's Avatar
You want thread chasers for cleaning, NOT taps. You want to remove rust, dirt, etc. If you have a stretched thread situation, taps will cut excessive metal out, and then you might strip a nut or bolt with proper torque.
Sharvey421
Dec 12, 2023 05:52 PM
Ingo85
Jul 6, 2020 12:55 AM
brinny
Nov 17, 2017 01:09 AM
Beavis
Mar 11, 2016 06:05 AM
ohsigmachi
Dec 24, 2012 08:09 AM
