Thelma's on the road again!
Old Sep 23, 2018 | 08:16 PM
Thelma86's Avatar
Default Thelma's on the road again!
Hello! New Jag owner, and new driver as well. I dont know alot about cars in general but I am interested in learning! "Thelma" my jag has been sitting for two years, my mechanic and I have got her running and I'm trying to learn as we go. Do you have any recommendation on sites or videos about jags i could check out? Any tips? My Thelma todo list is; install new stereo, fix exhaust leak(through the trunk), connect fuel tanks to empty equally, cosmetic touchups inside etc etc!
1986 jaguar xj6
Old Sep 24, 2018 | 06:42 AM
yarpos's Avatar
Congratulations, nice to see another one bought back to life. Your to do list is much longer than that, the items just havent surfaced yet :-)
Old Sep 24, 2018 | 09:35 AM
Hello,
As Steve has mentioned, if your car has been sitting for a while, there will be Numerous things needing attention, but if you get it drivable in the meantime, that will be the most fun for you. There's no better way to get to know a car than to drive it between repair projects.
Previous posts in this section (going back Years) will help you learn some of the more, um, Intricate problems you might encounter. Search function will lead you where you need to go.
Welcome to our little corner of the forums from ElinorB.
Old Sep 24, 2018 | 09:50 AM
JagCad's Avatar
Thelma's new steward.
Add your name. friendly folks here as well as most helpful in tech and encouragement.
Why change the fueling? I like the tank selection on my car. Once I got to understand it.
It differed a bit from my other two tank critter.
Caveat, if you simplify and add a "T' to connect the tanks, a side hill full tank issue can arise. there are cures,
If I were to mess with my fueling, which is not likely, I would add filters upstream of the pump.
Again, welcome, enjoy....
Carl
Old Sep 24, 2018 | 04:16 PM
Daf11e's Avatar
Well done, the fun has just begun.
shift
Oct 7, 2014 01:44 PM
Cambo
General Tech Help
Apr 21, 2014 11:21 AM
RJag
May 28, 2011 09:18 AM
XJRJeff
Dec 16, 2010 06:52 PM
jaginblack
Aug 17, 2010 06:15 AM
