Those blasted horns again!
Old Oct 12, 2018 | 11:35 AM
chrisleg's Avatar
Originally Posted by Doug
Yes, check relay connections
Terminal 85 - green wire ('key on' voltage)
Terminal 86 - purple/black (ground from horn button)
Terminal 87 - purple/yellow (voltage output to horns)
Terminal 30 - brown/purple (constant voltage)
If that checks out Ok then I'd remove the horn button. If the horn goes silent then you have a problem in that area. If the horn is still honking then you you have a problem with the grounding fingers, or somehow related to the grounding fingers.....possibly to the contact rings in the column falling out of position.
Will give the relay another once over today with the test light. I printed out the schematic you provided so I have more detail.
On the horn push. I took the horn push out and it was still honking yesterday when i was cleaning the contacts
Seems like it would be a simple issue to fix but alas hahahahh
Will get back to you all!
Thank you again!!!
PaulB
22
Oct 4, 2018 11:19 AM
lotuscorty
Dec 29, 2012 10:28 AM
2000CAXK8
Mar 30, 2012 02:01 PM
azureyes
May 9, 2008 07:54 AM
