Tiny Black Pieces that look like filter bits
Old Oct 8, 2016 | 01:33 PM
jordanmc's Avatar
Default Tiny Black Pieces that look like filter bits
I was running my ac yesterday which is finally back up and running and I noticed a bunch of little black foam pieces blowing out the vents. I assume this is a filter for the air but I can't find where it was originally. Anyone know?
Old Oct 8, 2016 | 02:51 PM
Doug's Avatar
At various places the ductwork has foam bands to seal the joints. The foam dries out, disintegrates, and get blown thru the system. Very common. There's no filter on the Series I-II-III cars
Old Oct 8, 2016 | 02:54 PM
jordanmc's Avatar
Default Old foam
Ok thanks. So nothing to worry about or fix I assume
Old Oct 8, 2016 | 08:04 PM
Doug's Avatar
Right, nothing to do...unless you want to disassemble all the ductwork to remove the dried out foam and replace with new. Big job; you probably have better things to do.
What's loose will blow thru into the car and into your face. In a few years some more might come loose.
CHeers
Old Oct 9, 2016 | 09:01 AM
JagCad's Avatar
If they really bother you, put the shop vac hose up to the vent and draw pout as much loose foam as possible.
It would not bother me a bit. The thing works, that is what counts!!!
Carl..
oldish git
23
Oct 7, 2016 11:01 AM
Eskr
Oct 4, 2016 11:42 AM
Roger_B
Oct 4, 2016 10:29 AM
carzaddict
Oct 4, 2016 08:52 AM
yugwmb
Oct 3, 2016 06:14 PM
