V12 constant ticking, normal or bad?
Old Jul 26, 2016 | 11:37 PM
Dixter's Avatar
Default V12 constant ticking, normal or bad?
Hey there Picked up a "1986 jaguar XJ12 Vanden Plas",its my first jag and im just growing to love it more and more got some things to fix up but i love the v12 its been running decent but theres a constant ticking noise under the hood, i cant hear it when the hood/bonnet is closed, when its open its pretty noticable and and speeds up with the RPM, but once the motor revs high enough it drowns out the noise
Here is a link to a video of the engine idleing
I was maybe thinking a dropped valve or tension for the timing belt but not to familiar with any of that so If you have an idea what it might be pls post suggestions , and if it is just the motor running regulary dont critisize , ive never owned a vehicle with a v12 before
Please help inform me on this engine
Old Jul 26, 2016 | 11:47 PM
Dixter's Avatar
Im thibking its running smoothly but just to be sure i want to know that sorta ticking sound is normal
Old Jul 27, 2016 | 03:52 AM
Firstly, welcome to the Forum.
That sounds like very noisy injectors.
It does not sound loud enough for tappets, and is definately NOT a valve seat issue.
NO timing belt on the V12, a very long chain and a boomerang style tensioner. Usually good for 500K miles.
I would get some serious Injector Cleaner, your market will have its favourites, and pour it into a tank with minimal fuel.
I usually pour the whole bottle into 20ltrs of fuel, and then DRIVE it, get some miles on it. That Cleaner will take a while to clean them up, but it will work. Repeat regularly.
I also detect a slight hesitation as you rev it, and that will be consistant with injector issues.
Old Jul 27, 2016 | 09:25 AM
JagCad's Avatar
I like Chevron's Techron. I'm sure others are as good or perhaps better!!!
At SMOG inspection time for my Jaguar. I run one tank down low.
Add only about 5 gallons of 93 . Add the large size bottle of parts store sourced TECHRON injection cleaner. Result, a concentrated dose of cleaner. Drive heartily for a week.
Then get it good and warm and immediately to the test station.
Carl
Old Jul 27, 2016 | 11:15 AM
Dixter's Avatar
Thanks for the reply and i will try that out and hopefully thats the issue im having
,cole
dinop
Jun 14, 2016 02:48 PM
dsnyder586
Apr 1, 2016 12:11 AM
TheWarlock
Mar 28, 2016 09:08 PM
racerx82
Dec 31, 2006 05:17 PM
Oct 11, 2006 07:18 PM
