valve tapping
Old Mar 23, 2014 | 09:19 AM
doghead08's Avatar
Default valve tapping
A few months ago-i changed my oil and went w 20/50. My valves were tapping-which I thought was caused by sludge getting inside the valves from a lighter oil and prob also cheaper. I had my truck mechanic do this instead of my reg jag mechanic bc it was convenient. The tapping is still there-what could I do to rectify this on my own or just play it safe and get it to my jag mechani c? Should I not drive the car until my mechanic looks it over?
Old Mar 23, 2014 | 09:32 AM
Doug's Avatar
How bad/loud/alarming is the tapping? Hard to put into words, I know. Does it sound like just one or two cylinders? Or all of them?
A very light tapping or clatter is perfectly normal....as it would be on any engine with non-hydraulic tappets. The normal clicking of fuel injectors adds to the symphony as well.
At the other extreme is the possibility that a tappet guide is walking upward and hitting the camshaft. This is bad and the noise is pronounced. Removing the cam covers for inspection will quickly reveal if this is happening. If not already installed a 'stake down kit' will prevent it from happening.
Have your Jag guy listen. He'll know.
Old Mar 23, 2014 | 10:56 AM
doghead08's Avatar
Thanks Doug-ill get it to him for inspection but I dont think its that bad based on what u said. The car runs fine just a little noisier than before.
Old Mar 23, 2014 | 05:07 PM
Jose's Avatar
in my 1984, the tapping is always present when engine is cold, and slowly goes away.
I always use Castrol 20W50 oil, nothing else. I also had the stakedown kit installed many centuries ago.
if I don't hear the tapping, I start to think something's wrong!
boiler
US Southwest
Dec 20, 2025 12:38 AM
bdboyle
Nov 6, 2015 02:07 PM
Johncy2000
Oct 2, 2015 01:05 AM
jjmiah217
Sep 28, 2015 09:09 AM
