Water Pumps
Old Mar 12, 2016 | 05:40 PM
adenshillito's Avatar
Default Water Pumps
Can anyone tell me which water pumps stocked by either Supercheap Auto or Repco are suited to the Series 2 engine as replacements for a leaking pump?
A model or serial number if possible.
Old Mar 13, 2016 | 04:04 PM
Fraser Mitchell's Avatar
The water pump is peculiar to the XK engine as first made in 1948. Later pumps had large impellers and there were one or two changes to the casting shape to suit later cars. You can buy replacement seal and bearing.
SNG Barratt - The Ultimate Jaguar Parts Specialist
Old Mar 13, 2016 | 04:20 PM
Fraser ~ by 'replacement seal and bearing' are you suggesting I repair the existing pump's leak rather than replace the unit?
Old Mar 14, 2016 | 04:20 AM
o1xjr's Avatar
I got an exchange one from Jagdaim, a bit over $100
Jaguar Spare Parts Supplier - Jagdaim - Australia's Largest Independant
Old Mar 18, 2016 | 08:17 PM
Supercheap Auto - Search Results for water pumps
any of these suitable?
Old Mar 19, 2016 | 12:48 AM
o1xjr's Avatar
nothing there looks like a match. These are the best pics I have.
Old Mar 19, 2016 | 03:04 AM
Originally Posted by adenshillito
NOPE.
I work, when called upon, in the aftermarket spare parts industry. The pumps from the likes of what you have suggested will NOT fit the S2.
I have looked at them many years ago, and came to that decission then, and see no reason to change that decission.
I have always got mine from JagDaim, including the V12 units.
They will need to know the V groove number on your pump pulley, and the "snout" diameter and length. That is from my memory as it has been a very long time since I needed one.
slojotaa
Feb 4, 2025 08:35 AM
Computer Budda
Mar 22, 2016 02:51 PM
cdnp62000
E type ( XK-E )
Mar 20, 2016 09:31 PM
F15DOC
Mar 15, 2016 09:50 PM
SD96XJ6L
Mar 7, 2016 10:55 AM
