What do these wingnuts hold?
Old Sep 23, 2021 | 02:11 AM
Bosco15's Avatar
Default What do these wingnuts hold?
Even though Lady Mable has a lovely tight bum, thanks to some PO work, she still needs new saddle bags.
Getting up close and personal with her unmentionables, I have discovered some fixings that I know not what function they serve.
Wingnuts under fuel filler area.
Something under the parcel shelf. Not the seat belt anchor, surely? They are on a galvanised plate that is putty sealed. The rest is sheet metal.
I am intrigued.
Why wingnuts?
It's not a very easy place to access, so not like they need to be easily undone. Why not normal nuts like everywhere else.
Those crazy Poms, back in the day.
Over to you, brains trust.
Old Sep 23, 2021 | 01:48 PM
Fraser Mitchell's Avatar
Ha ha ! Yes, I found this diaphragm at the top of the outside of the rear inner wheel arch when I removed the fuel tanks on my 1980 XJ6. However I don't remember them having wing nuts, though. As I recall, I removed the putty and soaked it in rust preventative called Waxoyl, a product on sale here in the UK, and got it nice and flexible again. With the space left by removing the putty, I squirted this waxoyl into the forward section of the wheel arch, then put the putty back. I don' think I ever removed the diaphragm. It seemed to me it was there to stop fuel vapour getting forward into the car. There would seem no other logical purpose. I also found putty had been inserted into the crevice where wheel arch and wing met at a welded joint. This was a notorious rust point, but due to the putty, mine was like new, so like the other seal, I removed the putty, squirted in yet more Waxoyl and onto the putty and replaced it. Even though this was a 1980 car, the WORST for quality in Jaguar EVER, I neve got any corrosion on the rear wheel arches.
Of course I found plenty elsewhere and that was why the fuel tanks were out, to repair the back end incl a new valance, quarter panels and boot floor, plus repairs to the rear of the rear wheel arches. All a long time ago in the late 80s..........."back in the day"
Of course, you could always remove the diaphragm and have a look-see. Post photos if you do.
Old Sep 23, 2021 | 04:19 PM
Bosco15's Avatar
I will be inside the rear wing, cleaning up and treating the surface rust, today.
I never even considered removing the putty. I assumed that being 50 yo, it would be hard and brittle. But, if it is still pliant, I will investigate further to see if there is more treatment required behind the diaphragm. I will post pics, if I delve deeper.
​​​​I am pleased to see how little rust I am finding, so far. Hopefully nothing major, but time will tell.
RaceDiagnostics
Nov 23, 2019 01:24 PM
dhatfield12
XJ40 ( XJ81 )
Aug 3, 2016 04:16 PM
RaceDiagnostics
Jul 30, 2016 04:55 PM
RaceDiagnostics
Jul 20, 2016 02:24 PM
Brake buster
Mar 4, 2008 04:28 PM
