What size is the fuel supply tubing on a 1985 XJ6? Is it 3/8" or 5/16"?
Old 12-16-2012, 10:42 PM
FastKat's Avatar
Default What size is the fuel supply tubing on a 1985 XJ6? Is it 3/8" or 5/16"?
I thought that my 1985 XJ6 had a 3/8" fuel feed line. When I put a new high pressure fuel line in the engine bay, I am 99% sure that I used a 3/8" hose. However, looking at the other end of the fuel system located in the spare tire well, it looks like I have a 5/16" fuel hose going from the filter into the line/bulkhead/fitting/? located in the front right corner of the spare tire well - where the green arrow is pointing.
The hose going to the whatever that is that exits the spare tire well is 5/16". Is that actually the end of the fuel line? Or is there some sort of fitting there
My end goal is go make everything 3/8" from the pump to the engine bay. It seems like there are more 5/16" parts here than I thought.
Any help or info would really be appreciated!
Attached Thumbnails What size is the fuel supply tubing on a 1985 XJ6? Is it 3/8" or 5/16"?-fuelpart2.jpg
Old 12-17-2012, 09:06 AM
icsamerica's Avatar
Received 1,359 Likes on 790 Posts
I've observied 5/16 after the pump and 1/2" coming out of the tank on fuel injected cars.
FastKat (12-24-2012)
Old 04-22-2013, 04:45 PM
FastKat's Avatar
Wanted to follow up on my own thread...
I installed a new fuel pump today and noted that the hoses on the supply/pressure side of the pump (inside the spare tire well) were 5/16".
I then put the car up on the rack to do an oil change. I measured the fuel supply line in several places, and it all measured out to 3/8" OD. I think there is a 5/16" hose forced over the 3/8" fuel supply tube that protrudes into the spare tire well area, making it appear 5/16" from the trunk when it's really 3/8". I am going to replace the fuel filter with a larger less restrictive filter and then I'll find out for sure.
Forcedair1
05-14-2023 03:28 PM
kelliott
05-31-2022 05:26 PM
alpecsa
09-07-2015 11:55 AM
RaceDiagnostics
09-07-2015 07:28 AM
AL NZ
09-04-2015 08:39 PM
Quick Reply: What size is the fuel supply tubing on a 1985 XJ6? Is it 3/8" or 5/16"?
