Where can I find high-performance rear IRS cage mounts?
Old Jun 21, 2012 | 04:52 PM
FastKat's Avatar
Default Where can I find high-performance rear IRS cage mounts?
Where can I find high performance IRS cage mounts for my 1985 XJ6? I
was surfing the net a few days ago and I thought I came
across a set of stiffer cage mounts, but now I cannot find them.
Any thoughts on this? Are all the mounts the same, or are
some better/stiffer than others? I am looking for something
more performance-oriented, but do NOT want to hard-mount the
cage directly to the chassis. I switched to some polyurethane parts on the front, and life the more connected feel.
Thanks, -Dave
Old Jun 22, 2012 | 03:57 AM
Fraser Mitchell's Avatar
I have never heard of high performance subframe mounts for these cars, but people who have raced them may know. The normal ones are, of course, still available. As the cars are so old now, and racing will not be common, I would not expect any HP mounts remain in production
Old Jun 22, 2012 | 10:02 AM
FastKat's Avatar
It looks like SNG Barratt USA sells them, part number CAC3067P. I finally found the ones I originally saw at Bob Beere racing, however his were about double the price.
Old Jun 22, 2012 | 02:45 PM
Excellent research and post !!
Old Jun 23, 2012 | 03:49 AM
I looked up these on the SNG Barrett website. The rubber has a higher "shore rating", so will be less resilient to movement.
File Type: pdf
Old Jun 23, 2012 | 08:06 AM
JgaXkr's Avatar
If you are looking to stiffen up the rear suspension have a look at the way Aston Martin does it on the DB9. It is on the XJS floorpan & is the same cage setup as the sedans. When I saw one on a lift I was impressed with the setup. It may require a little welding but well worth it.
RaceDiagnostics
Sep 7, 2015 07:28 AM
philwarner
Sep 5, 2015 10:05 AM
SouthernGypsy
Sep 3, 2015 10:54 AM
Harry Dredge
Sep 3, 2015 03:04 AM
innzane
Sep 2, 2015 10:08 AM
