Where is Fuel Filter??
Old Dec 18, 2009 | 09:41 PM
derby98's Avatar
Default Where is Fuel Filter??
Can anyone please tell me where the fuel filter is located on my 90 XJS coupe.
Old Dec 18, 2009 | 11:06 PM
m0t0rm0uth's Avatar
Typically they're under the car inside the left rear wheel. HOWEVER, that's on an XJ6. Not sure if the XJS is the same.
Here's something I found on the net:
be super careful about both a) the fact that it's going to spit fuel all over your driveway, and b) the bolt you have have to get off is a supremely rare 12mm banjo fitting. I broke mine and to wait like 3 months before anyone came up with a suitable replacement. It's a fairly simple process though. Jack up left rear wheel (driver side). Remove wheel, and put a jackstand on the support point. Seriously, you'll be getting under the car, so don't trust that stupid little jaguar jack.
Remove the banjo bolt w/ a 17mm wrench, then unscrew the filter from the y adapter on it's rear. (it helps if you unscrew the filter holder from underneath the car [after you rmove the banjo bolt, but before you remove the y adapter])
good luck and be extra careful with that fitting.
AGain, this is for an XJ6, and I don't know if they're the same.
Old Dec 18, 2009 | 11:54 PM
Doug's Avatar
On my '88 XJS V12 the f/f was behind the spare tire and used just hose clamps for attachment.
Yours is probably the same
Old Dec 21, 2009 | 09:54 AM
ken@britishparts.com's Avatar
In the trunk around the spare wheel is correct.
silkcat
Jan 18, 2025 04:29 AM
JWheeler
Nov 22, 2019 08:28 AM
shootingbrake
Sep 23, 2015 10:54 AM
axr383
Sep 18, 2015 11:19 AM
Sprayall
Sep 3, 2015 07:49 PM
