Is this where the idle screw is?
Old Apr 28, 2015 | 08:26 PM
Mike Beda's Avatar
Default Is this where the idle screw is?
Hi.
After some other maintenance I've got an unintended high idle speed (about 1100 rpm). So I'd like to turn that back down. I've read some descriptions of where the idle set screw is, but haven't found any pictures or drawings. Is this where that screw hides (red arrow to hole)?
Thanks,
-mB
Old Apr 28, 2015 | 09:32 PM
Doug's Avatar
No, that's not it
This might help
Idle Speed Adjustment
Old Apr 28, 2015 | 09:34 PM
Doug's Avatar
In this picture the air distribution block...where the idle speed adjuster is.... is the item between the #1 and the #2
https://www.jaguarforums.com/forum/a...tion-block.jpg
Old Apr 28, 2015 | 09:36 PM
Doug's Avatar
Originally Posted by Doug
No, that's not it
On second glance maybe that IS it. Hard to tell
Old Apr 29, 2015 | 11:57 AM
davidboger's Avatar
Just adding some photos to compliment what Doug has said... It's a little easier to see with the intake off the car...
David
Everyday XJ
Attached Thumbnails Is this where the idle screw is?-img_0714.jpg   Is this where the idle screw is?-img_0715.jpg
Old Apr 29, 2015 | 01:24 PM
Jose's Avatar
is the size of the hex wrench 7/32" ??
Old Apr 29, 2015 | 02:21 PM
davidboger's Avatar
I believe that to be correct Jose.. 7/32" is indicated in Doug's writeup above.... I just got lucky and grabbed the one that would fit from the allen wrench bin..
Old Apr 29, 2015 | 06:34 PM
Mike Beda's Avatar
Thanks very much, David. That's exactly what I needed.
-mB
workworkwork
Oct 23, 2015 10:26 AM
tomkilner
Oct 9, 2015 07:10 AM
Spazzzzzzzzzy
XJ40 ( XJ81 )
Oct 5, 2015 04:05 PM
inactualis
Oct 2, 2015 11:13 AM
