Window Problems
Old May 1, 2015 | 10:38 PM
Jsnyder0828's Avatar
Default Window Problems
Hi Everyone,
The passenger's side and the rear passenger's side windows on my 1985 XJ6 don't work. I bought new switches, but that didn't work. Both front and rear window switches don't work. I couldn't find any fuses related to the windows. I'm assuming there must be relays instead. Does anyone have any advice on what I should do?
Thanks!
Old May 2, 2015 | 12:31 AM
Doug's Avatar
A relay (extreme right side of dash, to the right of glove box) feeds power to two circuit breakers.....one breaker for left windows, the other for the right windows. If *any* of the windows are working the relay must be OK.
The circuit breakers are below the glove box (from memory here). You can check for voltage in/out with a test light. Or swap the breakers and see if the problem changes sides. Or use a jumper wire to bypass a suspect breaker and see if the problem goes away.
The breakers are about .75" square with red/slate wires
Old May 7, 2015 | 09:58 PM
Thanks! I'll check this out when I get back to the car. Will let you know if I run into any problems.
Old May 15, 2015 | 10:14 PM
DC73's Avatar
Is the sunroof a cable system? I can hear the motor running but it wont open or close anymore.
Old May 15, 2015 | 10:36 PM
Doug's Avatar
Yes, cables.
The cables may have come adrift from the motor. Remove the rear seat for a look-see. There was a recent thread about this.
Old May 16, 2015 | 11:44 PM
DC73's Avatar
Back seat? The sunroof is in the roof, and I have dropped the headliner but the motor and all other parts are encased in some kind of box.
Old May 17, 2015 | 12:32 AM
Doug's Avatar
I am vaguely aware of that, yes
What year and model do you have, and was it originally built with a sunroof?
Series III sedans with an original sunroof used a cable drive system where the cables ran down the C-pillars to the motor....which is mounted on the bulkhead behind the rear seat.
Edit:
If you have a Series III sedan and the sunroof motor is in the ceiling, it's an add-on sunroof
Old May 17, 2015 | 08:01 PM
DC73's Avatar
I have had the backseat and c pillars out and I didnt see anything like that, then again though that wasn't what i was looking for when I had them out. But when i pulled the headliner there was a black box mounted to the ceiling and the sunroof slid inside of that, and I didnt see any cables running out of it.
It's a 1986 SIII XJ6
Old May 17, 2015 | 08:04 PM
Doug's Avatar
I very strongly suspect you have an aftermarket sunroof of some sort.
Sometimes an installer will put some sort of identifying label in the glove box or door jamb.
Old May 17, 2015 | 08:05 PM
Doug's Avatar
I would be unusual for an '86 to have an aftermarket s/roof, though. Can you post some pics?
Old May 19, 2015 | 11:19 PM
DC73's Avatar
Yeah I can do that
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
GordoCatCar
Jan 2, 2017 01:10 PM
fingers
General Tech Help
Oct 21, 2015 02:02 AM
laserguy
Sep 3, 2015 02:02 PM
