Window switch wiring diagram problem
Old Oct 17, 2009 | 02:46 PM
m0t0rm0uth's Avatar
Default Window switch wiring diagram problem
Can someone PLEASE help me decipher the window switch diagram for my 76 XJ12?!?
I put in a different console cover, and THOUGHT I had done all the wires properly (I left the old switches plugged in until I was ready to swap them, then pulled one wire, put it where it belonged, then went to the next wire, and so on), but apparently something went wrong. I looked at my wiring diagram in my Haynes manual, but the colors seem all wrong (unless I'm just not looking at the right wires). PLUS, they don't show which wire goes on which plug, necessarily...it just shows which wires goes to which switch.
HELP ME!!!!!!!!!! None of the switches work. Every so often, I hear a click under the dash, and can roll the driver's front window down, but then the click happens again, and the window won't work.
Old Oct 18, 2009 | 02:10 PM
m0t0rm0uth's Avatar
I figured it out. Pictures to come once I get all the wires sorted.
Old Oct 22, 2009 | 11:58 AM
m0t0rm0uth's Avatar
OK. Here are the pictures of the mess of window switches and wires on my 76 XJ12.
In the first picture (100_5802):
215 - Main switch (lock-out switch)
216 - passenger side window switch
218 - driver's side window switch
217 (left) - front switch for rear driver's side window
219 (left) - front switch for rear passenger side window
217 (right) - rear switch for rear driver's side window
219 (right) - rear switch for rear passenger's side window
220 - window motors
Second picture (100_5798): what the back of the switches actually look like. Notice that NONE of the plug things line up like in the wiring diagram.
Third picture (100_5797): the back of the window switch panel between the front seats. Notice that NONE of the wires are perfectly straight, nor do they line up like in the diagram...lol.
Attached Thumbnails Window switch wiring diagram problem-100_5802.jpg   Window switch wiring diagram problem-100_5798.jpg   Window switch wiring diagram problem-100_5797.jpg
Old Jun 7, 2015 | 01:00 AM
adenshillito's Avatar
trying to do this with a 74 XJ6 at the moment,
spaghetti mess of candy colours, not even sure they are working at all.
wondered if the small central window lock rocker (which is my case is broken) might be essential to the rest of them running, like do they daisy chain at all or might the central lock have locked them before it broke hence they dont operate.
is there a published list of which colours go where and why?
Old Jun 7, 2015 | 02:34 AM
If you're unsure of the center switch (which is indeed necessary for all else to work), merely connect both wires together behind the console. That switch only closes a circuit to make the windows work. I put a jumper in my wires and repurposed the switch for another task.
Old Jun 7, 2015 | 02:46 AM
Look at this thread, reply #60:
https://www.jaguarforums.com/forum/x...-130996/page3/
There you will find color maps of Series 2 window switches, all except the back seat switches.
I hope this is of assistance to you.
Old Jun 2, 2017 | 11:34 AM
njk1963's Avatar
Default Series 2 XJC rhd window switch wiring
Just spent 3 days working out the wiring for my coupe
The Haynes schematic was hard going but got there in the end
Hope this is of some help
Front right 216
1 Red Blue
2 Green Purple
3 Green
4 Red Brown
5 Red Purple
6 Green Blue
Front left 218
1 Red Green
2 Red White
3 Green Purple
4 Red Purple
5 Green white
6 Green Red
Rear right 217
1 Red yellow
2 Green black
3 Green white
4 Red white
5 Red pink
6 Green yellow
Rear left 219
1 Red orange
2 Green pink
3 Green black
4 Red black
5 Red pink
6 Green orange
Rear right console 217
1 Red yellow
2 Green light green
3 Green pink
4 Red pink
5 Red light green
6 Green yellow
Rear left console 219
1 Red orange
2 not in use
3 Green light green
4 Red light green
5 not in use
6 Green orange
Old Dec 8, 2018 | 07:35 PM
Nic Graves's Avatar
thanks for that explanation spot on ! I now have rear window controls much appreciated.
Old Dec 9, 2018 | 06:40 AM
njk1963's Avatar
Default You’re welcome
You’re are welcome
Old Nov 15, 2023 | 08:57 PM
Wyzawazza's Avatar
Hello I find myself in your situation, I was wondering if had anymore photos of the rear of the ski slope the part that backs into the center console
‘’many many thanks Warren Thomas
Old Nov 16, 2023 | 10:55 AM
These might be a bit Large, but the better to see what's there.
I hope this is of help to you.
JarodL
Mar 7, 2024 01:39 AM
jdzubas
Oct 4, 2015 09:14 AM
arnoldmilk
Sep 3, 2015 07:42 PM
laserguy
Sep 3, 2015 02:02 PM
TC Johnson
Sep 2, 2015 09:30 AM
