Windows won't roll
Old Jun 16, 2015 | 12:06 PM
Jagmare's Avatar
Default Windows won't roll
So I read somewhere that jag electrics when not used stop working, I'm having that issue. The car has been laid up in the garage for a few months so I haven't moved the windows. Now, they won't move at all. Not up, not down. Just a click from under the dash from the thermal relay.
Anyone had this issue? Any recommendations where to start?
Old Jun 16, 2015 | 05:18 PM
Richard_gib's Avatar
Default Windows won't role
the isolation switch between the window switches?? fuses?? Gremlins under the dash?
is it all of the windows not working?
i think there was a similar thread a few weeks ago about windows
Old Jun 16, 2015 | 05:37 PM
Jose's Avatar
if the sunroof doesn't work either, you might have turned the Master Switch OFF.
Old Jun 17, 2015 | 09:52 AM
JagCad's Avatar
YUP!!
Been there, done that!
Carl
Old Jun 18, 2015 | 12:18 PM
Jagmare's Avatar
Yes, all windows are not working and I don't have a sun roof. Now, I did have to pull out the dash to rip out some aftermarket alarm system (stupid) and I think a power line may have been tied into the switch panel, but it doesn't look like I'm missing any wires to the panel.
Old Jun 18, 2015 | 01:16 PM
JagCad's Avatar
Is there voltage at the master switch? If not, they ain't gonna work.
1. Jump the switch. It can get corroded inside. Not hard to remove, take apart, clean and reassemble.
2. Jump 12 v to the master? Work back to the source of power. More than likely a white power wire. White is powered only with ignition on.
3. Wild shot; Is the ignition on, when you try a window? Must be to work.
Carl
Old Jun 18, 2015 | 02:05 PM
Jagmare's Avatar
Carl, where is the master switch? And yes, the car was one when I tried.
Old Jun 18, 2015 | 02:12 PM
JagCad's Avatar
The master for windows only is on the console, I think. Mine is, but my car is later, an 83 XJ wuzza six.
Do you have an owners manual? The documents are crucial.
I am about to sit at the table and peruse mine!!
Carl
Old Jun 18, 2015 | 11:10 PM
Default Window Master Switch On Ski Slope
This is the Master Window Switch.
There are only 2 wires to it, a simple On/Off switch, unless someone repurposed it in the past.
Old Jun 20, 2015 | 07:21 PM
Jagmare's Avatar
I don't have a master switch in mine. And no, no owners manual. I'm going to need a new window motor for the front drivers side...may or may not have made a rookie mistake and broke it. Easily sorced though. On the upside, after cleaning the control switches, I have back lighting to my gauges. Still have many connections to clean and grease so will see if that helps.
Old Jun 20, 2015 | 08:19 PM
Jose's Avatar
those window motors are GM, at least in the Series 3 they are, you might pull them from 1980's GM cars.
Old Jun 20, 2015 | 10:41 PM
Jagmare's Avatar
Yup, they came in the 66 corvette too so I can get a remaned unit. That isn't the problem though I don't think as all of the other windows still arent working. Even with a switch clean and regrease.
99xk8guy
Sep 29, 2025 10:51 PM
GordoCatCar
Jan 2, 2017 01:10 PM
rentzoo
Nov 10, 2015 04:56 PM
SeanU
Sep 18, 2015 03:38 AM
RaceDiagnostics
Sep 13, 2015 02:22 AM
