Windshield wiper bezel gaskets?
Old Aug 14, 2019 | 01:56 PM
4catstudio's Avatar
Default Windshield wiper bezel gaskets?
I need to source wiper bezel gaskets, that odd oval rubber gasket with a tiny lip that sits under the cover on the wiper wheel post and keeps at least a little of the damp out. Have checked the usual suspects - Barratt, Welsh, Terry's, Everyday Jag, and fleabay without success. Any input would be appreciated.
Thanks, Richard
PS: Yanking the soaked mat out of the driver's side split the accelerator pedal at the hinge seam.
Sheesh, you'd think 42 year-old rubber would hold up better.
Old Aug 14, 2019 | 02:20 PM
Jose's Avatar
search the forum, someone found them last year.
Old Aug 15, 2019 | 09:16 AM
yachtmanbuttson's Avatar
Well, I didn't exactly find them, but I found something close. See the link below for where I got them. They are for an XKE and I was hoping they would fit. Their oval shape was just a bit too long. So I cut them width-wise using an X-acto blade to the appropriate slightly smaller size, then glued them back together with Q-Bond (GREAT STUFF!). Job done!
Products
Old Aug 15, 2019 | 02:10 PM
4catstudio's Avatar
I found a "wiper escutcheon seal" at Barratt that corresponds to the factory part no., C5522R. They label
it as suitable for Ser.II XJ. So I ordered 2 and we'll see if it works.
Old Aug 16, 2019 | 12:49 PM
Jose's Avatar
You can also try those for MG-B and Triumph for the same years. I was told British Leyland parts were used in many marques.
Old Aug 18, 2019 | 10:16 AM
4catstudio's Avatar
Default Wiper post gaskets
Just an update; the SNG Barratt part is a perfect match to the factory original, including the formed lip around the edge.
FactoryP/N C5522R
Old Aug 18, 2019 | 10:22 AM
Jose's Avatar
so they don't have the part but they do?
Old Aug 18, 2019 | 12:45 PM
4catstudio's Avatar
Default wiper post gaskets
My initial search was flawed; once I had an original part no. I found it.
One vendor who shall remain unnamed replied it was never available separately. I knew that was incorrect,
although my info on that was decades old. The illustration @ Barratt left a lot to be desired, but the application list said it was correct,
and it is.
Lesson learned? Search, and research, harder
Old Aug 18, 2019 | 02:52 PM
Doug's Avatar
Almost surely he was thinking of the Series III cars when he said that...in which case he would've been correct. For those, the gasket sold as part of a repair kit, RTC2881
Sean B
Dec 8, 2022 07:42 AM
DanielEllensjag
Jan 14, 2020 12:41 PM
JaguarXKR
Mar 25, 2013 02:48 PM
nebelfuerst
Feb 6, 2013 06:10 AM
OldMike
Apr 30, 2012 08:33 PM
