XJ6 1971 fuel pump/s and lines questions
Old Aug 31, 2022 | 07:36 PM
rsq911's Avatar
Default XJ6 1971 fuel pump/s and lines questions
Hi everyone!
Got the new tank put in and all is good with that.
The questions…..
With carbs, and one non original fuel pump, do I need to use a second pump and all the plumbing, or….. can I put the “Y” in front of the single pump and just have the tanks connected together? There are no return lines or check valves.
Thanks in advance!
Old Aug 31, 2022 | 08:57 PM
Bill Mac's Avatar
That will work OK however if you park on a transverse slope ie sloping to one side, fuel will run from the higher tank to the lower tank. (Not a great problem if the tanks are only half full.)
By having two fuel pumps before the Y they each act as non return valves not allowing fuel to flow from one tank to the other
Old Sep 9, 2022 | 07:45 PM
rsq911's Avatar
Thank you! I went ahead and did it that way, and all is great!
Except….. when switching tanks, the new fuel tank/sending unit is not showing full, it drops to zero.
lofc2909
Jun 26, 2022 03:30 AM
Navy
21
May 13, 2018 04:45 PM
John Gloyd
Feb 25, 2016 05:13 PM
GTBentley85
Mar 19, 2009 09:56 PM
wnlewis
XJ40 ( XJ81 )
Oct 31, 2008 11:00 PM
