Xj6 series 3 exhaust
Received 10,782 Likes
Assuming a 6 cylinder Series III....
The inlet end is 1.875" OD
The outlet end is a little tricky. The actual outlet nub is 1.75" OD but it almost immediately necks down slightly in diameter and curves upwards...with the bend leaving an less-then-round section of pipe that is a little difficult to measure. Ultimately it goes back to 1.875" OD at the rear of the car where the rear muffler fit
I assumed, perhaps incorrectly, you were talking about the forward mufflers.
If you want rear mufflers, this might be of interest
https://www.jaguarforums.com/forum/x...6-12-a-146097/
When you remove the existing rear mufflers don't cut off too much of the existing pipe or you won't have a good round surface to clamp the new muffler onto. It's another case where the pipe-to-muffler joint is perfectly round but the pipe curves and tapers just ahead of the joint....
Nothing bad will happen. Slight increase in noise. It's a rather odd tone without the front mufflers.
No front mufflers and the glasspacks replacing the rear mufflers might be a bit louder and sound OK
cheers
Thrush Turbo/Universal muffler 17696- ReadReviews onThrush Turbo #17696
^^^^^^ This one is close and a good fit but with 2 inch ports. If your pipes are in good condition they can be cut off expanded a bit and welded inside the end of the new muffler.
I've done this...they offer a subtle but noticeable increase in sound over new OE units. The OE units are really heavy and packed thus their quietness.
Should be in stock at your local auto-zone or other big box auto parts store. Can also be ordered out of the catalog from just about any parts store.
Antonio Di Fonso (04-24-2023)
Received 8,995 Likes
Jacob67
04-20-2019 06:17 PM
