11.5 Compression? Holy Octane, Batman...
Old Sep 23, 2020 | 04:37 PM
gthawk1's Avatar
Default 11.5 Compression? Holy Octane, Batman...
I was just reading the Owner's Manual (for the first time), and, I noticed the XJS has a compression of 11.5 to 1. Uh, shouldn't I be using premium gas? I've been using 87 octane all this time. There is no pinging. What is recommended? What do the other club members use?
Old Sep 23, 2020 | 04:51 PM
BenKenobi's Avatar
All you need to know >> XJS Octane
Old Sep 23, 2020 | 05:40 PM
jerry_hoback's Avatar
Surprise!!! It wouldnt hurt to try a couple of tankfuls. My xj6s both say "Premiun unleaded only" on the gauges.
Old Sep 23, 2020 | 06:37 PM
jal1234's Avatar
I run ethanol free gas, and that's only available in premium in my area. For cars that aren't driven all that much, ethanol free is better since it doesn't absorb water, and the XJS fuel system was not really designed with ethanol in mind.
Old Sep 23, 2020 | 06:55 PM
VancouverXJ6's Avatar
You need the highest octane possible in your area. If Marelli car you can select lower octane fuel via a wire plug however that severely hurts performance. Its ugly.
Old Sep 23, 2020 | 10:08 PM
We got the real engine, 12.5:1. so Hi Octane is all we use. 98 RON its known as down here.
Differnt markets called for different things, and distributor timing, emissions systems, etc etc were all :market specific" BACK IN THE DAY.
Old Sep 28, 2020 | 06:19 PM
Mguar's Avatar
The way they do that is by retarding the timing. Earlier Jaguars had 9.0-1 compression in England and the rest of the world except America we got 7.8-1
after 1980 England and the rest of the world got 12.1-1 compression while America got 11.5-1.
The early car 1975-1980 had 40 degrees of timing while the HE only has 17 degrees of timing.
what does that mean to you? If you drive it gently you’ll get by for a while using 87 octane. Eventually you’ll burn valves and maybe put holes in your pistons. And spend a lot of money getting it fixed or selling it cheap to someone who will fix it.
91-92 octane will prevent that.
I know all the talk about premium is a waste of money. Not all the time!! Most cars run fine on 87 octane. Not Jaguars.
Old Sep 29, 2020 | 07:29 AM
Timeisrelative's Avatar
My 93 4.0 says "premium only" as does my 97 xk8, so that's what I run. I figure if I can't afford the extra for premium, I probably shouldn't have the cars. Lol.
Blue Jag 2017
Jul 30, 2020 03:14 PM
Steve W
Mar 29, 2020 09:27 PM
jehart49
Aug 9, 2014 11:47 PM
buddyluv
Oct 6, 2012 07:34 PM
Reverend Sam
Jul 29, 2010 12:26 PM
