1984 Jaguar xjs v12 just purchased
Old Jul 22, 2023 | 11:17 PM
BruceCarlo's Avatar
Default 1984 Jaguar xjs v12 just purchased
Just last week I purchased a 1984 Jaguar xjs with a V12. Everything was working properly, power windows, wipers, wiper washers, blower motor, horn and there may be a few more things that aren't working right.
I didn't dig into it yet but I took the fuse box cover off and the fuse panel looks perfect, but of course I will check all the fuses tomorrow. Is there a specific relay that anyone knows about that could be causing the main problem because I cannot believe that all of these fuses blew simultaneously.
any help would be appreciated
Old Jul 23, 2023 | 12:19 AM
Welcome to the Forums.
I do not know of a relay for all that on an 84 car. Later years, yes.
BUT
You are UP HERE, and your market called for some weird stuff at times. Members in your market will know 100%.
Sometthing has shorted, and you will spend many hours/days/weeks maybe, going through each circuit quietlyu and systematically.
I always suspect aftermarket items, alarms, imobilisers, etc. so if these are fitted, REMOVE THEM, get the wiring back to Factory spec, and begin from there. These are SIMPLE cars in the true meaning of that phrase.
Old Jul 23, 2023 | 07:39 AM
BruceCarlo's Avatar
The only thing I could see in the car that is aftermarket is the cassette radio stereo. I am going to go through the fuses today and see if they are okay.
Old Jul 23, 2023 | 08:37 AM
Doug's Avatar
There is a "Load Relay" on the left component panel under the dash. It powers-up 3 or 4 fused circuits. Might be worth checking. For identification, it has brown, black, and white/pink wires
Old Jul 23, 2023 | 12:22 PM
89 Jacobra's Avatar
Active Streak: 30 Days
Usually when a bunch of circuits go dead all at once. Looking at the wiring diagram, and figuring out if they are connected to each other, and where? Can lead to a quick fix. I did mention "Usually" Good Luck
Jack
Old Jul 23, 2023 | 03:22 PM
jal1234's Avatar
Wiring diagrams are here:
JagRepair.com - Jaguar Repair Information Resource
Old Jul 23, 2023 | 08:03 PM
BruceCarlo's Avatar
Originally Posted by jal1234
this car is a pretty unmolested example of a 84 xjs V12 and it's running. The car was pretty much kept tidy but it still needs full restoration
stan73
Jul 18, 2023 01:19 PM
stan61
Aug 7, 2020 07:14 PM
Roberto54
Aug 6, 2014 09:39 AM
luds1
May 8, 2014 11:53 AM
