1989 jaguar xjs transmission questions
Old Sep 23, 2016 | 08:37 PM
Paulie206's Avatar
Default 1989 jaguar xjs transmission questions
Hi im looking for info. I recently bought a 1989 Jaguar xjs but the transmission was not in it I have a transmission from a 1988 Jaguar but I am concerned with fitting it because the did not have the crank position sensor on the '88. I would like to know where this speed sensor that zsits by the flywheel actually sits. Because mine is just hanging down on the drivers side by the oil filter
Old Sep 23, 2016 | 09:00 PM
Doug's Avatar
It's been years but I recall the sensor being mounted in the lower flywheel cover. This (vague) illustration somewhat supports my memory
Flywheel Covers-5.3 Litre - Parts For XJS from (V)179737 to (V)226645 | Jaguar Classic Parts UK
Old Sep 24, 2016 | 03:10 AM
baxtor's Avatar
Doug is right. You need number 3 in that diagram. Number 12 is also associated with the sensor, but is only a heat shield.
Old Sep 24, 2016 | 09:22 AM
Paulie206's Avatar
Awesome so you think if i found #3 in diagram it would work with my '88 transmision? Right now the car only cranks but no fire. The guy i purchased it from said he sent it to the transmission shop for repairs and they ripped the transmission out and ripped the sensor out in the process and that is why it won't start. I will post pics later. Engine looks nice
Old Sep 24, 2016 | 05:43 PM
warrjon's Avatar
You will need #3. My car did not have the heatshield, and the trans had never been out.
Without the sensor on the flywheel the car will not start. The Marelli ECU needs this for engine speed, without it, the Marelli does not even see the engine cranking so will not provide tach signal to Lucas FI ECU so no injector firing.
My car is getting a 4L60e ATM so if you need any more pics let me know.
Attached Thumbnails 1989 jaguar xjs transmission questions-p_20160925_081448.jpg   1989 jaguar xjs transmission questions-p_20160925_081520.jpg
carzaddict
Sep 19, 2023 11:09 AM
Jim Goodall
Nov 2, 2020 08:24 AM
jeff71
Aug 30, 2016 09:35 PM
rainbowboy
Aug 29, 2016 10:27 AM
StuG
Australia - Queensland
Aug 28, 2016 08:42 PM
