1989 XJS V12: Fuel Injector Hose Clamps
Old Jan 3, 2022 | 09:26 AM
67Camaro's Avatar
Default 1989 XJS V12: Fuel Injector Hose Clamps
I purchased an injector rebuild kit from Ebay and it all looks good except it came with clamps instead of the original ferrules. Are the clamps ok to use or should I find replacement ferrules? If so, where can I buy just the ferrules? Thanks!
Old Jan 3, 2022 | 10:07 AM
67Camaro's Avatar
Sorry, never mind. Found them. www.jaguarfuelinjectorservice.com $60 for a set of 24.
Old Jan 3, 2022 | 10:13 AM
Doug's Avatar
I wouldn't use clamps, personally. The risk is that clamping the hoses will cut them, as the barbs on the nipples are very sharp. For ferrules, try Dave at :
Jaguar Fuel Injector Service
And/or search the archives ("fuel hose ferrule") for other sources. They're not really Jaguar-specific
Old Jan 3, 2022 | 01:57 PM
alabbasi's Avatar
Clamps are fine, you need the heavy duty type that can hold under the pressure. They've been used since the dawn of time.
Old Jan 3, 2022 | 02:11 PM
Doug's Avatar
Also fine, and in use since the dawn of time, are pressed-on hoses over barbed fittings . There's nothing remotely exotic or unsafe about them.
Some guys do use clamps, yes. There's no particular reason to use them, though, except perhaps a feel good thing....which I understand. If you do use clamps it really doesn't matter if they're heavy duty or light duty or anything else, as the nipple design doesn't require them in the first place ! Once you press that hose on, it ain't comin' off for love nor money!
Old Jan 3, 2022 | 04:20 PM
alabbasi's Avatar
Originally Posted by Doug
Also fine, and in use since the dawn of time, are pressed-on hoses over barbed fittings . There's nothing remotely exotic or unsafe about them.DD
Not really Doug, barbed fittings can leak under pressure. That's why hose clamps exists. Yes they should be fine under normal circumstaces but who plans for the norm when you deal with gasoline? We could probably go back and forth on this but it's pointless. You'll tell me that there's no problems and I'll point out plenty of V12 jags that have burned to the ground.
67Camaro
Nov 22, 2021 03:12 PM
jerry_hoback
Dec 21, 2020 08:25 AM
NCJagman
Jul 5, 2018 11:59 PM
TheWarlock
Mar 28, 2016 09:08 PM
J_C_R
Mar 26, 2015 09:20 AM
