1990 Jaguar XJS Front Bearing Replacement
Old Apr 26, 2020 | 06:39 AM
JayJagJay's Avatar
The soft line is attached upside down, JJJ. However, if it is long enough to not be stretched at all when on full lock AND full suspension travel, it will be OK. If you change it round, you will have to make a new hard line of course.
Shims: read carefully:
  1. The steering arm is attached to the top of the upright, above the inner end of the stub axle
  2. The steering arm is ALSO attached to the upright TOGETHER with the BOTTOM caliper fixing bolts.
  3. This bottom caliper bolt goes: a) through the arm, then b) through the caliper, then c) through into the upright (as shown by the lockwired bolt in the photo below.
  4. Because the top bolt of the steering arm goes into the upright, and the bottom caliper bolt goes into the upright in a different plane, it is possible that the two bolted surfaces are not exactly parallel to each other.
  5. To ensure that this possibility does not result in a permanent bending moment on the steering arm when all the bolst are tightened, you have to insert a shim between the arm and the caliper to take up any space that may be there when the top steering arm bolt is tightened.
  6. So the procedure is to a) loosely insert the top caliper bolt not quite even finger tight, then b) loosely insert the bottom bolt through the arm and caliper into the upright but not even finger tight, then c) do up the top steering arm bolt tight, then d) tighten up the TOP caliper bolt, then e) try a feeler gauge to see if there is a gap between the arm and the caliper on the lower caliper bolt!
  7. If there is, get shims to this thickness and insert them, somehow into the gap!
Don't you love these cars!
Haha... Strangely I Do! I really do. Have an interesting place growing in my heart for this one here...
Damn Greg. Amazing post and I will follow it...
I'm posting a photo. Is the shim the area I circled and,,, it goes on the OUTSIDE? I would have thought that it would be between the first and second layer of the arm and caliper combination. I can't even understand what effect a shim would have way out there so close to the bolt head.
But, ok!
Finishing work now. COViD mess has me on 3ed shift. Home to get some zzzzzzzz's. Talk soon!
Old Apr 26, 2020 | 07:10 AM
Greg in France's Avatar
No, that is a washer under the bolt head. The shim cannot be seen but is between the arm and the caliper, as you correctly supposed.
Old Apr 26, 2020 | 07:15 AM
JayJagJay's Avatar
Understood...
many many thanks...
Old May 3, 2020 | 01:05 PM
JayJagJay's Avatar
The inner RH bearing looked pretty good. The RH outer bearing roller,,, not so clean. The inside of the race pretty spotless and the outside rim, not so clean. A bit "sticky" when trying to roll it between thumb and forefinger... The stub, on the outer, had a couple light groves... I think I'll have to live with that a while.
db057
Aug 27, 2017 07:16 PM
joeboat84
Feb 15, 2013 03:07 PM
emaraszek
Jan 28, 2013 08:30 PM
Mgmagnette
May 17, 2012 09:24 PM
chknhwk
May 29, 2010 02:27 PM
