1990 Jaguar XJS - Misfire B Bank cylinder 6
Old Jun 5, 2020 | 07:09 PM
  #41
JayJagJay's Avatar
One other thing.
I have a bunch of these. Read about them in a thread on the forum. They fit the coils perfectly. I believe the gauge is even a bit thicker than what I have. A safe replacement, ya think?
My A coil plug (gold yellow stripe) is messy, cracked insulation, wire appears to be intact. The B bank, wires are fine but the male shaft of the plug itself has seen better days.
Old Jun 6, 2020 | 01:25 AM
  #42
Greg in France's Avatar
If they fit Ok, no reason not to use them, but be sure that the wires to the loom are in the correct order.
Also, JJJ, if you have cracked coils connectors, you must change them ASAP.
Old Jun 6, 2020 | 07:54 AM
  #43
JayJagJay's Avatar
I do... They are brittle, and cracked, and I am sure that's how the tab in the OE coil was bent over - missing the slot in a cracked connector. This last round of fiddling only made things worse. I plan on grabbing my heat gun, shrink tube and connectors and doing this tonight after work.
It was foolish of me to be running that car around with such a messy set up. There are maybe 2 or 3 places where a small ignition electrical storm could have stalled out the car at 75mph...
It's amazing. At first,,, the work that needed doing needed doing with large tools, hammers and fire. Now, as time goes on, the work is getting more and more detailed. Cruise control, AC, speedometer and all involved with reading the speed - all on the list. It's gunna be interesting.
Thank you, Greg!
Old Jun 11, 2020 | 07:24 AM
  #44
orangeblossom's Avatar
Hi Jay
If one of your Injectors isn't/wasn't working or your Ignition system is faulty, it could lead to a Carbon build it which could increase the Compression in that Cylinder, which if left unchecked could (in extreme circumstances!) either start melting or blowing a hole in your Piston!
That is what I read somewhere but Greg and Grant will know for sure
Old Jun 11, 2020 | 08:25 AM
  #45
Originally Posted by orangeblossom
Hi Jay
OB, the poor guy spends half his time fretting about the car as it is! I think this is something he need not worry about, more likely the excess fuel has washed the combustion chamber clean!
Old Jun 16, 2020 | 06:03 PM
  #46
JayJagJay's Avatar
Hmm. Wasn't fretting. It was something I caught, and glad I did. Surprised I did actually, especially since these are my first significant drives after 2+yrs of work to bring a car that sat for 12yrs back from the dead.... I'm surprised (and a little proud of myself) that I noticed 1 out of 12 cylinders misfiring, on a computer-less car that I am unfamiliar with, blowing unburned fuel into a hot exhaust system.. Definitely had a bad/dead cylinder. Now I don't. Discovered (with help) it was a cracked cap on one of the fuel injectors. Replaced it along with dizzy, rotor, both coils and coil plugs. All needed and overdue. Problem solved.
Now, top of the engine off, between road trips, to deal with a near dangerous set of top end oil leaks where so much oil is running down the lengths of the exhaust pipes, smoking, near burning. Not fretting there either. It's needed work I now know after the first 400miles.
Then, got a new black fan to replace the exploding 30yo yellow fan. Needed. And,,, a creature comforts AC compressor came in and I found a guy to fab me some tubes and hoses.
In the mean time,,, rehabbing an 86 Porsche 928 that sat for 6 yrs,,, and a Jag XKR Supercharged Portfolio that's sat for 4,,, she went underwater (fresh) in Texas...
Need help with alllll.
Anywho,,, I promise. I'll be posting less. Don't wanna be bothering folks.
Old Jun 16, 2020 | 06:24 PM
  #47
VancouverXJ6's Avatar
No! The forum is the one thing that is still sane and normal in this clownworld! I need this for theraputic reasons.
Old Jun 17, 2020 | 01:21 AM
  #48
JJJ
Please do not take this as a criticism of you! It was teasing OB for thinking the worst unnecessarily. I for one, am full of admiration for how you are going about sorting out the car. My sincere apologies if you took my post as a dig at you. The forum is exactly for guys, like us all, who to begin with knew nothing about the cars.
Do keep posting as required.
Old Jun 17, 2020 | 01:58 AM
  #49
JASON,
i\If you stop posting I will have nothing to read, and then have to talk to Greg on the phone more, I LIKE GREG, but Vodafone only gives me so many minutes per month.
JOKING GUYS.
Post away, I remember way back in the dark ages a quote:
"There is no such thing as a dumb question........." and that applies here and anywhere else on these Forums.
How else are we going to learn, and have the archives for the younger generation to look up when we are gone.
I need a drink Jason, YOUR shout.
Old Jun 17, 2020 | 08:17 AM
  #50
JayJagJay's Avatar
Thank you all...
I apologise.
I think I was having one of those thin skinned moments.
Shouldn't be reading so much into things, lol...
I still have a bunch O questions...
You asked for it
JX350
Nov 6, 2018 09:53 AM
UKcat
Aug 19, 2018 03:24 AM
Flappers
Jul 12, 2018 10:25 AM
AndrewG
Nov 15, 2017 03:44 AM
BradsCat
May 21, 2017 11:25 PM
