1990 XJS 3.6 wont start
Old Nov 3, 2019 | 12:19 PM
A.giles's Avatar
Default 1990 XJS 3.6 wont start
Hi, new to this forum.
I have recently bought a 1990 Jaguar XJS 3.6. When I turn the key it turns over but wont start however if I get someone to disconnect the Inertia fuel pump switch while I am turning it over and then switch it on again (While the car is still turning over) the car will then start. Any ideas on what the problem could be??
Thanks!
Old Nov 3, 2019 | 04:10 PM
orangeblossom's Avatar
Hi A.giles
Could be a faulty Inertia Switch or may be a break in the Inertia Switch Wiring
Are you sure you have a 3.6?
A 1990 XJS is a V12 5.3
Old Nov 3, 2019 | 04:20 PM
A.giles's Avatar
Ah you’re right. It could be a late 89 model. It’s G reg. definitely a 3.6 though.
I will look for a new switch to see if that solves the problem and also have a look at the wiring!
thanks for your help
Old Nov 3, 2019 | 04:26 PM
ptjs1's Avatar
A.giles,
Although only a tiny number went to the US, 3.6 XJS were made from 1983 - 1991.
Also suspect you have a n inertia switch problem
Good luck
Paul
Old Nov 4, 2019 | 04:39 AM
A.giles's Avatar
I have found a new switch so hopefully when it arrives it should solve the problem. Thanks for your help!
Old Apr 3, 2021 | 08:41 AM
A.giles's Avatar
Default Problem solved
Finally found the fault! Turned out to be the fuel pressure regulator. The diaphragm had split. Ordered a new one and fitted it, it started straight away!
Old Apr 3, 2021 | 10:25 AM
leep123's Avatar
Hi, glad you got it sorted.
I have a '90, G registered 3.6 also. Mine is a manual. What transmission does yours have?
Shout out with any more queries - lots of knowledgeable guys on here.
Cheers,
LeeP
Old Apr 3, 2021 | 10:38 AM
A.giles's Avatar
Very Nice! Mine is an auto. And yes, I have another issue with it il probably have to make a new thread although I’ve already read through some similar ones. Sometimes when I brake the car dives to the left, I might make a proper thread and go into more detail about it! Nice one for the reply 👍🏻
Old Apr 10, 2021 | 08:17 AM
leep123's Avatar
Great looking car and nice colour.
Regarding brakes occasionally pulling to the left have a look at the recent thread about brake pump running continuously. PTS has replied with a comment about ABS pulling to one side which might be relevant.
Cheers,
LeeP
Old Apr 15, 2021 | 06:23 AM
A.giles's Avatar
Thanks, appreciate that! I will have a look.
andystev
Oct 12, 2019 08:50 PM
markman
Sep 21, 2018 05:44 AM
orangeblossom
Sep 3, 2014 12:57 PM
chipkent
Jun 23, 2010 09:56 AM
