1991 XJ-S brake and air conditioning problem
Old Feb 2, 2013 | 03:36 PM
dsetter's Avatar
you may also require a pressure reservoir that holds pressurized brake fluid. Replacements are available. The brake pump should be used to pump the fluid our.
check both fans are running on the a.c.. If only one runs the air does not circulate correctly.
Old Feb 2, 2013 | 07:08 PM
Sarc's Avatar
Hi Jim
The center vent failure is fairly common..... read this thread for info
https://www.jaguarforums.com/forum/x...froster-74545/
Old Feb 2, 2013 | 09:38 PM
macboots's Avatar
Gravity draining the brakes ain't going to cut it. I have personally used this kit to bleed the brakes on my XJ-S by myself and it worked reasonably well:
Brake Bleeder and Vacuum Pump Kit
Major issue is one of the bleed valves sucked air through the threads which slowed things down some. I think next time I bleed the brakes using that system, I will first remove the bleed valve and wrap the threads with teflon tape to make the job go smoother.
Regarding your a/c problem, as Sarc says air out the defroster vent is a common issue with multiple possible sources.
In my case it was a faulty solenoid. To avoid repeating myself, please check out the following thread where I posted a method to troubleshoot the cause:
https://www.jaguarforums.com/forum/x...ng-well-80282/
Bonus: you can use the vacuum pump in the brake bleeder kit to troubleshoot your vent issue...
Cheers,
- Will
Wait, is this thread really from 2006?
Old Feb 3, 2013 | 01:30 AM
Greg in France's Avatar
Is this really a thread from 2006??
Just in case not:
If yours is a 1991 model, it has an anti lock brake system. Normal brake bleeding procesures will NOT bleed the system. Someone here will know the proper procedure, and it is in Kirbert Palm's book. I believe, but an NOT sure exactly, that it involves having the ignition on and activating the anti lock pump system bu pressing the brake pedal.
FWIW, I respectfully strongly advise you NOT to drive the car until the brakes are properly bled with new fluid.
Greg
BrentGardner
29
Dec 16, 2024 12:13 AM
DrScientist
Dec 9, 2015 07:36 PM
johanasu
Sep 3, 2015 12:39 PM
martybmw
Aug 31, 2015 10:15 PM
tonydbaker
Aug 30, 2015 11:02 PM
