1992 v12 free up hp
Old Oct 26, 2016 | 01:10 AM
revski666's Avatar
Default 1992 v12 free up hp
hey guys i have a 1992 xjs V12 if i pull off all my catalytic convertes how much horsepower would i free up? and would their be any warning lights pop up on my dash
Old Oct 26, 2016 | 02:46 AM
warrjon's Avatar
US cars from what I have seen have a catalytic element in the downpipes. Lost of people remove this from all 4 pipes.
If your Cats are working properly and not blocked removing them (Not the ones in the PIPES) will have very little difference on a stock engine.
To increase the power on the 5.3L there is a couple of things you can do.
Remove the Cat elements in the downpipes.
Increase the size of the trumpets on the air filter boxes
Fit a cold air intake, this can be over the radiator like the TWR cars.
Fit K&N filter elements.
Here is a pic of what TWR did for CIA on the XJS. You can just see it in the bottom right of the pic.
Old Oct 26, 2016 | 06:25 PM
JigJag's Avatar
Warrjon,
I've read the published specs for the US catted 5.3 is 30hp lower than the same model in EU config ( no cats ). Was that incorrect?
Old Oct 26, 2016 | 09:26 PM
Mish_Mish's Avatar
EU model had different valve clearance and compression ratio of 12.5:1, instead of 11:1 for US model. I removed all cats on my '82 HE and gained better power, but only because my lower cats were half melted. That power increase also came at a cost of awful fuel consumption, due to lack of back pressure. Right now I plan installing generic converters in place of the empty lower units. Also I will do what Warren suggested above, for noticeable power gain.
Old Oct 26, 2016 | 09:35 PM
sidescrollin's Avatar
Isn't it more likely that your bad fuel mileage is from poor fuel/air ratios since your lambda sensors are reading nothing?
Old Oct 27, 2016 | 12:28 AM
revski666's Avatar
SWEET so iF i pull all of my cats off, i will get 30 HP? but will i get any check engine lights on my dash
Old Oct 27, 2016 | 02:28 AM
Daim's Avatar
Originally Posted by JigJag
Warrjon,
My cat- and lambdasond-free 89 has according to its papers 295 bhp which would result in 302 ps. Just a 'TMYK' fact...
Models with cats had around 268 hp (272 ps) here in Germany (mine is a UK import).
Old Oct 27, 2016 | 02:31 AM
Greg in France's Avatar
Warrjon,
It is correct, at least for pre facelift V12s anyway. The US version has a lower compression ratio and cats, etc.
Greg
Old Oct 27, 2016 | 02:33 AM
No, as Warrjon explained, that will not do much. You need induction changes as well as the European spec compression ratio.
Greg
Old Oct 27, 2016 | 03:39 AM
warrjon's Avatar
An engine needs air to create power, fuel is then added to make correct AFR. Around 12 to 13:1 for power (max torque) in a NA car and 14.7 to 15:1 for cruising leaner if the engine is resistant to detonation.
Just removing the Cats will result in very small power gains. To take advantage of the free flowing exhaust you need to get more air (actually OXYGEN) into the engine.
EU and Aussie spec cars had higher CR due to the higher octane fuel available in those markets, this makes a HUGE difference as the additional Quench acts to cool the charge as it's Squished helping to reduce detonation.
My Australian spec 1989 with O2 sensors and Cats is listed at 213kW (284hp). TWR managed another 30hp from the 5.3L with CAI, larger intake trumpets, K&N Filter and free flowing exhaust.
As far as I can tell all Jaguar did to adjust the CR for markets was to change the head gasket thickness. The parts catalog lists a couple of different part numbers.
Old Oct 27, 2016 | 05:09 AM
I have often wondered and asked people, but nobody seemed to know. This seems a very sensible way to do it, can anyone 100% verify? I have a friend who wants to up his CR from US spec to UK.
Greg
Old Oct 27, 2016 | 06:51 AM
Doug's Avatar
Different pistons!
Old Oct 27, 2016 | 06:57 AM
Originally Posted by Doug
Different pistons!
Is that definite, Doug? excuse my asking.
Greg
Old Oct 27, 2016 | 11:08 AM
Jonathan-W's Avatar
What happened to that 5 degree advance?
https://www.jaguarforums.com/forum/x...ssible-128515/
Old Oct 27, 2016 | 03:38 PM
warrjon's Avatar
Doug is right there is standard and high compression pistons listed for the HE.
Old Oct 28, 2016 | 09:25 AM
Jonathan-W's Avatar
only saw standard for my 5.3... jaguar-sport high and low...
oh any one need the standard VE numbers for the 5.3
Old Oct 28, 2016 | 02:41 PM
No point in going above 5,500 RPM then! Where did you get these figures, Jonathan? Are they for the USA spec engine?
greg
Old Oct 28, 2016 | 07:04 PM
JigJag's Avatar
greg
This makes those big throttle bodies look WAY more attractive!
Old Oct 29, 2016 | 03:17 AM
warrjon's Avatar
The stock throttle bodies flow 600fcm EACH, putting bigger ones on is a total waste of time.
My 6.7L will run stock TB's with just a profile on the inlet and velocity stack.
Old Oct 29, 2016 | 06:05 AM
JLBolen's Avatar
Kirby Palms book has a section talking about increasing the airflow, minor modifications to the air filter housings and milling a radius on the throttle body outer side to smooth the flow.
