1992 XJS Convertible Body Q?
Old Feb 17, 2016 | 08:08 PM
RAC's Avatar
RAC
Default 1992 XJS Convertible Body Q?
Ahoy!
I've not found the procedure in the Service Manual so, time to source the wisdom of the Forum.
Re: 1992 XJS Convertible (Facelift)
How is the "A" pillar finisher (trim) removed ? And, I need to know where to start: how to remove everything before I even get to the finisher.
I am a new member. This is my first post so, please accept my apology in advance if I unintentionally violate any protocols. And, I need to lear how to navigate the Forum.
Richard
Greater Chicago Metro, U.S.A.
Old Feb 17, 2016 | 09:51 PM
Doug's Avatar
Welcome aboard
My memory is a bit foggy....others will chime in....but I think the pillar finishers are simply levered off. One of those things that makes you a little nervous.
Old Feb 18, 2016 | 01:32 AM
Greg in France's Avatar
On a pre facelift, there are two screws under the door closer rubber seal that must be undone, if you lever up the seal they are there.
Greg
Old Feb 18, 2016 | 04:09 PM
RAC's Avatar
RAC
Thanks, Everyone
How is the lower windshield "chrome" trim removed ? The upper has several screws hidden beneath the rubber but, I'm not sure about the lower.
Re: Gingerly prying off the "A" pillar finisher: Any tips, tricks, recommended tools? Certainly with caution and a steady hand.
Go well through your day.
Richard Cielec
Chicago Metro, U.S. A.
Old Feb 19, 2016 | 03:48 AM
Once the A pillar trim is off, it reveals a screw each end of the under screen trim. In addition you must remove the windscreen wiper grille and mechanism (it comes out as one assembly) and two more screws are then revealed in the centre
Greg
Old Feb 19, 2016 | 07:26 AM
Doug's Avatar
Silly me, I was thinking of the *interior* trim on the A-pillar.
Anyhow....
When working with any of the 'finishers' be gentle. They bend/distort quite easily and, if that happens, you'll have hell to pay getting them to fit and look right.
Old Feb 19, 2016 | 02:54 PM
ptjs1's Avatar
RAC,
I'll try and dig out my pics from a few years ago, but I thought I remembered a rivet on the side chrome on a convertible? I might be wrong.
As Doug has mentioned, go very easy, it's incredibly easy to slightly distort them and a pig to then get them lined correctly on refitting. Also.be very careful once you've got the side chrome off. As you probably know, XJS are notorious for getting rot in the windscreen lower flange and spreading into the scuttle. It's very likely that the screw fixing point for the lower chrome is corroded and in a corroded area. So, go easy.
Good luck
Paul
msteiner805
May 25, 2020 01:10 AM
harvest14
Feb 18, 2016 01:52 AM
DavidXK
Feb 17, 2016 09:20 AM
msteiner805
Feb 14, 2016 10:14 PM
Mr G
Feb 12, 2016 01:49 PM
