1992 xjs convertible rear speakers
Old Mar 20, 2014 | 04:23 PM
ukester's Avatar
Default 1992 xjs convertible rear speakers
how do you get the rear speaker out of the rear passenger compartment-it has the pump and such-cannot even get at the screws? Also door speakers how to get the panel off-one last question rear antenna lead how to replace.
thanks mark
Old Mar 21, 2014 | 08:25 AM
Noah's Avatar
thanks mark
I've tried to upload a pdf of the door panel and rear stowage removal.
You have to remove the rear cubby (stowage area) to remove that rear speaker. The service manual sort of glosses over "remove the rear quarter trim panels". I recall having to remove the plastic trim piece at the end of the sill plate. Then pull back the furflex out of the way. Seems like there is at least 1 visible screw somewhere on the rear quarter panel. And there is a plastic screw/finisher that is visible behind the rear quarter windows on each side (windows have to be down obviously). Then the panel should pop out - it is held in by the push in pull out plastic rivets like a door panel. Then remove the cubby per the manual.
When removing the door panel, you have to pull back the chrome finisher at the front of the arm rest to expose a torx bolt. Use some tape to protect the leather, or a lubricant safe for leather to make it easier.
File Type: pdf
XJsc-guy
Nov 23, 2015 01:56 PM
RaceDiagnostics
Sep 7, 2015 07:28 AM
philwarner
Sep 5, 2015 10:05 AM
obwoodie
Sep 3, 2015 07:45 PM
SouthernGypsy
Sep 3, 2015 10:54 AM
